Replacing stock variable a/c compressor with something else???
Old 05-17-2009, 01:47 AM
jw33's Avatar
Default Replacing stock variable a/c compressor with something else???
Is there a sanden or other style a/c compressor out there that will mount in the same location as the stock LS2 V7 a/c compressor? I'd like to run a/c in my car, but I'm not looking forward to the misc sensors and controls to get the variable style compressor to work.
Old 05-18-2009, 11:19 AM
LS1GMCTruck's Avatar
Everything is more or less the same, no matter what compressor you go with. Its no big deal.
Old 05-18-2009, 03:38 PM
Bo185's Avatar
I remember someone saying the early Gen III trucks used non-variable ones. May be check those out 99-2000?
Old 05-18-2009, 07:43 PM
RE AND CHERYL's Avatar
It only has one sensor which has a low press and high press switch in it. How many less sensors do you want?
Re'
Old 05-19-2009, 01:54 PM
Rodder's Avatar
The refrigerant AC pressure sensor has nothing to do with using a fixed or variable displacement compressor. The AC pressure sensor allows the PCM to do the functions of a trinary switch (cut out compressor at high/low high-side pressure, turn on fans, and kick up idle). I'm using a 99 LS1 Camaro's refrigerant AC pressure sensor with my Sanden compressor and Vintage Air GENIV system.
Old 05-20-2009, 09:28 AM
69 Ghost's Avatar
If you want you can convert your compressor from a variable to a fixed. I posted a thread do a search. I am going to use my compressor with a vintage air setup. Don't believe that a variable compressor will not work. The biggest issue is that the rest of the system should be setup for a R134 and hopefully not a R12 retrofit setup.
Old 05-20-2009, 03:44 PM
Nooner's Avatar
I think the question is 'what other applications will bolt up to the stock bracket?'
I am interested in the same - please share if you find any info.
Old 05-20-2009, 05:57 PM
Slow50h's Avatar
they make a bracket to use a Sanden R134a 508 Compressor on LS1 its not a dual stage like stock. the whole setup would cost about 350 but save headaches i would think
Old 07-04-2009, 05:33 PM
99'CajunFirehawk157's Avatar
Who is they?
Old 07-06-2009, 02:52 PM
Originally Posted by 99'CajunFirehawk157
Who is they?
yah, who dem?
Old 07-06-2009, 03:43 PM
John McGraw's Avatar
BRP
Regards, John McGraw
Quick Reply: Replacing stock variable a/c compressor with something else???
