Cylinder No. 7 Disaster
Old 05-17-2009, 06:31 PM
JoeMack's Avatar
Default Cylinder No. 7 Disaster
First run at track after FAST install and this is what happened. It's really hard to see it but the cylinder wall is also split. Unbelievable. How does this happen?
Here's some more pics. The only thing I see with the head is a couple of nicks on one of the valves from the pieces of broken piston bouncing around in the chamber. Also, the two small pieces of piston were found inside the intake. How the hell did that happen?
Old 05-17-2009, 06:36 PM
vsocks1's Avatar
Any nitrous spray? What was your AFR?
Old 05-17-2009, 06:40 PM
BigRich954RR's Avatar
Id have to say went lean/bad gas/ to much timing/ engine had some knocking and bam done.
Im running close to 16 psi of boost on stock piston but but im **** with my tune and A/f ratio
Old 05-17-2009, 07:49 PM
JoeMack's Avatar
No nitrous. Told it was a safe tune.
Old 05-17-2009, 08:14 PM
Bville99gt's Avatar
Did you clean the chamber and piston to inspect it? or this was the way it look when you opened it?
If this was the way it looked when opened, it looks like a lean condition.
How did the plug looked? Maybe the injector went out.
Old 05-17-2009, 08:40 PM
DaveX's Avatar
Did you have it tuned after installing the intake? If not it could have been running leaner than it was before due to more airflow.
Old 05-19-2009, 12:54 PM
JoeMack's Avatar
Yea, I cleaned the head up too see if there was any damage. Also, when the cylinder spit it let coolant in cleaning it up a bit too.
Old 05-19-2009, 12:56 PM
JoeMack's Avatar
It was tuned after intake install.
Old 05-19-2009, 01:29 PM
topher455's Avatar
Usually those pistons do that because of ring butting due to high pressure/temperature in the cylinder. I know that #7 cylinder has distribution issues with the factory intake but you said you are running the fast intake. Did you check the injector o-ring on that cyl? You may have had a vacuum leak on that hole. Oddly enough I have a piston on the bench next to me that looks identical to yours. It was caused by a clogged injector.
Old 05-19-2009, 03:18 PM
JoeMack's Avatar
No I haven't looked at the injector yet.
Old 05-19-2009, 04:21 PM
PlatnumStatuz's Avatar
bad tune, detonation and maybe too rich
Old 05-20-2009, 12:26 AM
brianfromhawaii's Avatar
Hard to tell what happen really, you tampered with the crime scene!!
Old 05-20-2009, 02:53 PM
Old Geezer's Avatar
Bad tune would have likely gotten more than 1 cyl.
"Distribution problems"?
Looks to be a topic in this thread:
https://ls1tech.com/forums/generatio...inder-7-a.html
Old 05-20-2009, 03:05 PM
Soul TKR's Avatar
Is it just me... or does that whole sentence contradict itself...?
Old 05-20-2009, 03:27 PM
BobDoLe's Avatar
i think he's saying it could have run rich or it could have run lean?
i'm thinking cooling issues (coolant lines) have something to do with the #7 or at least contribute to.
on a side note: my level 6 brute (bobdoless) savagely RAPED your level 12. you couldn't even take my dog out.
Old 05-21-2009, 01:30 AM
05gto60's Avatar
it was probably the green coolant he was using!!!!
lol, jk
Old 05-21-2009, 12:34 PM
topher455's Avatar
Yep thats what I was referring to. If you add boost it gets even worse.
Old 05-21-2009, 12:36 PM
topher455's Avatar
Check out post 15 in that thread too.
Old 05-21-2009, 12:39 PM
Pauls325's Avatar
i think number seven is easy to run too lean. there are two guys in the ls4 section who ran nitrous and f-ed up their number 7 cyl just recently
