Getting closer New Best.
Old 05-19-2009, 05:26 PM
BADHAWK51's Avatar
Default Getting closer New Best.
Went to Byron Dragway on Sunday with Speed Inc looking to run a ten second pass on nuts with a new tranny |FLT level 4| and a |Circle D 4000 coverter| had a couple new best but came up just a hair short of my goal. Still a good day for some of us and not so good for others.
11.040 @ 121.94 NA 1.52 sixty New best et & mph
11.132 @ 119.75 NA 1.46 sixty New best sixty
Heres the slips car 617.
Had a new best 60ft also.
Old 05-19-2009, 05:35 PM
airfix's Avatar
Right on dude, almost cracking into the 10's
Old 05-19-2009, 05:38 PM
ABA383's Avatar
Thats badass!! Its great to see more LT1s gettin it done n/a style...Congrats!
--Alan
Old 05-19-2009, 05:41 PM
BADHAWK51's Avatar
Thanks.
Old 05-19-2009, 05:44 PM
BADHAWK51's Avatar
--Alan
Thanks Alan, I think the converter made a big difference just needs to be a touch looser.
Old 05-19-2009, 06:09 PM
AChotrod's Avatar
yep thats one bass *** LTX!!!! I was one of the others
Old 05-19-2009, 06:11 PM
ss.slp.ls1's Avatar
That .041 seconds must be eating away at you!
Old 05-19-2009, 08:15 PM
BADHAWK51's Avatar
Thanks,
You bet your *** it is.
Old 05-20-2009, 12:43 PM
ABA383's Avatar
I'm hoping for 10s this year also...The times in my sig were with a Vig 3600, Spohn street 1" rear bar and 275 60 M/T radials...This year I'm running a Vig 4000, Spohn Pro series rear bar, and 325 50 M/T radials...If I can get the damn thing into the high 1.4s to 60' I think I'll have it...That and for added insurance, have my 115 lb fiance drive the thing...That's a 100 lb weight loss! I'm hoping adding 400 more stall rpm will help it hit harder...Feels realling good on the street and those big Mickeys hook much better than the smaller 275s...at least in street testing...
--Alan
Old 05-20-2009, 02:41 PM
BADHAWK51's Avatar
--Alan
Good luck Alan I think you will get it but I would be a little concerned about the extra rolling mass of the 325's.
BTW I'm still on the stock rear bar and the car was twisting pretty bad with the way that converter was hitting. I'm defiantly going to invest in a spohn.
My best sixty that day was a 1.46 but I only ran a 11.132
Old 05-20-2009, 04:32 PM
ABA383's Avatar
The extra weight is a bit of a concern, but we'll see...I also want to try the M&H 325s as they are lighter and a hair narrower...I also lost 35 lbs off of my own *** since last year so I'm hoping my personal weight loss offsets that of the tires...The new bar makes a huge difference back there at least it feels much better on the street...We were able to set the suspension preload very easily with the big Spohn bar back there. Now the car hits very hard and goes straight...I'm thinking that if I hade your 1.46 I would have my 10.9X...
--Alan
Old 05-20-2009, 04:45 PM
vanilla89's Avatar
that's bad ***.. You going to the shootout??
Old 05-20-2009, 05:05 PM
BADHAWK51's Avatar
--Alan
Good luck keep us posted.
Thanks,
Yes I'm going just didn't preregister yet. How about you ? are you going with the other boys from Texas.
Old 05-20-2009, 09:26 PM
vanilla89's Avatar
Thanks,
ya. im going.. if you are running the extreme street class me and you are going to be a close race...
Old 05-20-2009, 10:52 PM
Z-RATED94's Avatar
BadHawk, what are your shift points and at what rpm are you crossing the line at? If you don't mind me asking that is. Rick
Old 05-21-2009, 09:58 PM
BADHAWK51's Avatar
Unfortunately I have to run in the modified na class.
My shift points are set at 6800 and it goes through the traps about 6600.
Old 05-22-2009, 07:17 PM
vanilla89's Avatar
How come??? Is your car real light or something?
Old 05-22-2009, 09:03 PM
BADHAWK51's Avatar
I'm running Brodix heads so my intake has been welded. Your class states no welded intakes. It kinda sucks to because my car is not an all out drag car so I'm going to get murdered in this class.
Old 05-22-2009, 09:21 PM
vanilla89's Avatar
That sux.. You just need a LT4 intake.
I just put a 93' intake on mine
Old 05-22-2009, 09:31 PM
BOLO's Avatar
Jeff, best of luck at the shoot out. I know I'll be reading about you and Larry in the future issue of GM HighTech.(post LTX results)
Quick Reply: Getting closer New Best.
