nut size for 6.0 truck manifold stud
Ok this may seem dumb to some people but I can't figure it out!
I've done a search about a 100 times
I'm trying to install my turbo kit and I can NOT figure out the size of the nuts for the 3 studs on each manifold where the crossover or whatever bolts to!
Please help that's all I need then ill erase this thread I'm getting tired of running back and forth to the hardware store.
The threads are a little rusted up so that is probably part off my problem if some one could give me the exact specs for the nuts you'd make my life so much easier thanks!!
they wernt 3/8-16 they were even finer thread then that
but i got pissed off removed all the studs taped the holes and put all new studs in with nuts to fit them
problem solved!!!!!
thanks
problem solved!!!!!
thanks
haha i just took my manifold to the hardware store i got M10x1.5 too, that was for my stock manifods off my ls1 not 6.0's but im sure its the same anyway, make sure the stud is clean
maybe i should think before i try things! lol my manifolds came coated and while the studs "looked" ok, they needed to have a wire brush taken to them and then the nuts went on, snug the whole way up but they were the correct size....that being M10 x 1.5's.
glad i found this thread and thanks for the input.
