Will the GT-67 support 15 PSi???????
Hey guys i have a 99 Camaro just got done with the engine its now forged i had a GT-60 on my car & actually blew it up now i need to upgrade to a bigger turbo money is a little tight right now so my question is will a GT-67 support 15 psi???? I know they say its good for 750 crank horse but how much will this turbo support at the rear tires & will it be fine at 15 psi Just needed to know before i go & buy this turbo cause i do want to run roughly around 15 psi.thanks guys
at 4500rpm u may have 15 psi, but at 5000 you may have 12, and at 5500 10... rough bull **** numbers of course, but you get the point, it cant flow enough cfm... its not about PSI, psi is bull ****, psi means restriction, CFM is what matters... if you can get 1000 cfm at 5 psi ur doing way better than 800 cfm at 30 psi
