ported ls6 pump only 48 psi wot!
Hey guys, need some suggestions and opinions on what I should do. I have a fully built forged motor and I'm using a ported and shimmed ls6 oil pump. At cold idle I see 49 psi pressure and 220 degrees hot I see 24 psi at idle. Problem is oil pressure does build with rpms, but maxes out at 48 psi at anything over 5000 rpms. This scares me as I want to pull the motor to 6500-6800 rpms. Why does the pressure not increase anymore? Any suggestions?
You would be surprised how bad things have to be for an engine to die. 3v fords only have about 35psi at 7000 RPM.
Ive also run ZZ4s to 7000RPM at 25psi and never had a problem, even tore apart the bottom end and all the bearings looked perfect.
I would find out if indeed it is possible to have a mechanical bleed off, or if something is wrong causing it to bleed.
Try the easy stuff first. Change oil and filter. I used a fram once because my usual ac delco was out of stock that day. Lost 15psi of oil pressure. Fram=****!
