228r cam with 59cc heads
Old 06-02-2009, 08:05 PM
Gregorya24's Avatar
Default 228r cam with 59cc heads
im using a stock gm head gasket and stock pistons, do yall know if i will have any ptv clearence problems thought i would see what yall say before i give texas speed a call tomorrow. thanks greg
Old 06-02-2009, 09:36 PM
Gregorya24's Avatar
no one?
Old 06-02-2009, 09:49 PM
corvet786c's Avatar
IMO i would think so with stock gaskets.
Old 06-02-2009, 09:57 PM
Gregorya24's Avatar
thats what i was thinking too, ill be sure to give tsp a call tomorrow and talk to one of the guys over there!
Old 06-02-2009, 09:58 PM
Restricted User
willyfastz's Avatar
I assume your going to measure, but just wanted to ask also.
Old 06-02-2009, 10:04 PM
Gregorya24's Avatar
of course im going to measure, the cam i have no isnt gonna clear im just gonna make sure the 228r cam is gonna clear even though im gonna check it out before firing over the motor
Old 06-02-2009, 10:31 PM
Super Hulk Smash
JakeFusion's Avatar
What kind of heads? What valves, etc...
Old 06-03-2009, 01:21 AM
PREDATOR-Z's Avatar
The question you should ask is (By how much will it clear?) and how much PTVC are you confident on running?
Also with that size of cam, high compression is not needed. IMO you should shoot for 11:1 which would give you comfortable PTVC and power benefit. That would require 62cc with .052 gasket or 61.5cc to be sure (if gasket a tad thicker), so I vote for 61.5cc max mill with the 228/228 112 LSA.
Old 06-03-2009, 12:21 PM
PonchoFan's Avatar
No clearance problems with 228R cam and Prc 5.3 Stage 2.5 heads with 59cc
chambers and GM gaskets.
Been on mine since March '08.
Old 06-03-2009, 01:06 PM
PREDATOR-Z's Avatar
But what are your clearances?
Old 06-03-2009, 01:24 PM
WSsick's Avatar
^^exactly.
youll probably clear but by how much? how much PTV clearance is comfortable for you?
Quick Reply: 228r cam with 59cc heads
