View Poll Results: How long did your stock motor last with boost?
LESS than 1 year
7
26.92%
1 year
2
7.69%
2 Years
2
7.69%
2 years +++
15
57.69%
Voters: 26. You may not vote on this poll
How long did your stock ls1 last with boost????
Old 06-02-2009, 08:51 PM
Restricted User
1BAD_LS1's Avatar
Default How long did your stock ls1 last with boost????
I am curious to know how long your STOCK motor lasted with boost with stock compression.... with exception to springs, pushods, injectors, fuel pump....
Please reply with:
DD or Garage queen???
what psi you ran???
What was the RPM's did you run it up to???
How many miles (aproximately)???
Less than a year / 1 year / 2 years / 2 years + ????
How "SAFE" was your tune???
Intercooler / Meth / Both ???
Thanks for the input again guys!!!
Blaine
Old 06-02-2009, 08:59 PM
Only ERO's's Avatar
Originally Posted by 1BAD_LS1
Please reply with:
DD or Garage queen??? In the middle. About 6000 miles last year. Not bad for Minnesota.
what psi you ran??? 8 lbs
What was the RPM's did you run it up to??? 5800
How many miles (aproximately)??? 6500
Less than a year / 1 year / 2 years / 2 years + ???? A little over a year
How "SAFE" was your tune??? Tune was pretty rich, not sure of the A/F though.
Intercooler / Meth / Both ??? Dual intercoolers
See responses above
Still running though. Not sure if this helps.
Old 06-02-2009, 09:05 PM
Restricted User
1BAD_LS1's Avatar
Only ERO's this is EXACTLY what i was looking for!
Keep it coming guys!
conan's Avatar
https://ls1tech.com/forums/forced-in...lity-list.html
Old 06-02-2009, 09:17 PM
Restricted User
1BAD_LS1's Avatar
theres alot of good info in that thread... thanks!
Old 06-03-2009, 08:46 PM
Restricted User
1BAD_LS1's Avatar
more than 2 years has the most votes! that suprises me... but it does settle my nerves about installing my STS turbo.
Old 06-03-2009, 10:02 PM
73 nova guy's Avatar
DO IT! lol they make new parts every day for that reason!
Old 06-03-2009, 10:54 PM
WS6HUMMER's Avatar
Nitrous & then some boost here.
Old 06-04-2009, 12:38 PM
00Z-28Maro's Avatar
DD or Garage queen??? Drove it to work some but mostly just on weekends
what psi you ran??? 7-9
What was the RPM's did you run it up to??? ~5800
How many miles (aproximately)??? ~10k
Less than a year / 1 year / 2 years / 2 years + ???? just over 2 years
How "SAFE" was your tune??? pretty safe, 11.2 afr was the leanest I went at the track. Most of the time it was in the high 10s afr.
Intercooler / Meth / Both ??? FMIC and meth.
Old 06-04-2009, 02:16 PM
dreamls1's Avatar
DD or Garage queen??? DD so far and running good..
what psi you ran??? 8 lbs creep to 12psi
What was the RPM's did you run it up to??? 6000
How many miles (aproximately)??? 500
Less than a year / 1 year / 2 years / 2 years + ???? less than a year
How "SAFE" was your tune??? safe.
Intercooler / Meth / Both ??? intercooler
Still running strong!
Old 06-04-2009, 08:34 PM
Restricted User
1BAD_LS1's Avatar
thanks for the input and votes guys!
I like how you all are running more than 5psi and are still running strong! Have a feeling i wont stay there long though! LOL
Old 06-05-2009, 05:49 AM
Mark98SS's Avatar
DD or Garage queen??? Race car
What was the RPM's did you run it up to??? 6900
How many miles (aproximately)??? 60,000
Less than a year / 1 year / 2 years / 2 years + ???? 2-1/2 years-150 10 sec passes
How "SAFE" was your tune??? fairly safe until I put the meth to it & got greedy with ign advance then it went ka-boom
Intercooler / Meth / Both ??? FMIC most of it's life, meth the last month before it died as detailed above
Old 06-05-2009, 11:45 AM
Hugger Z's Avatar
DD or Garage queen??? DD in the warmer months
what psi you ran??? 7psi that came on the kit
What was the RPM's did you run it up to??? I did not change the redline. It's bounced off the limiter a few times.
How many miles (aproximately)??? Over 18k since the install
Less than a year / 1 year / 2 years / 2 years + ???? Installed fall 2007, still running strong!
How "SAFE" was your tune??? Safe Street Tune
Intercooler / Meth / Both ??? Intercooler
Old 06-05-2009, 06:00 PM
40Mike's Avatar
DD or Garage queen??? - Daily driver, Silverado RCSB 5.3 with Maggie Ford 9" with 3.89's and 4L60E with 2800 TC built by Finish Line Trans.
What psi you ran??? - 8Lbs, 5800
What was the RPM's did you run it up to??? 5,800 thru the traps at Last years Hot Rod Drag Week 12.53 / 108 MPH with a 1.71 60'
How many miles (aproximately)??? - I put the SC on and drove 5,400 miles to Drag Week and back home with more than fifty 1/4 mile runs during the week long event and since then have added another 12k of daily driving
Less than a year / 1 year / 2 years / 2 years + ???? - in August it will be 1 year
How "SAFE" was your tune??? - safe tune by Kenny Duttweiler on Magnachargers chassis dyno
Intercooler / Meth / Both ??? - Both, the IC comes with the Maggie kit and I added a Snow Meth kit per Kenny's suggestion
Building a new 7 liter Warhawk with new TVS huffer for this year Drag Week, engine is done and are waiting on the TVS to LS7 head tub then its out with the old 5.3 and in with some real HP - I need it to get my 4,660 Lb truck down the track LOL...
Old 06-06-2009, 02:36 PM
Rick_Vor's Avatar
DD or Garage queen: DD comute to work + weekends
what psi you ran: 10lbs
What was the RPM's did you run it up to: 6200
How many miles (aproximately): 25,000
Less than a year / 1 year / 2 years / 2 years +: 2 1/2 years and counting
How "SAFE" was your tune: No idea. Tuned on the street by Rick at Synergy
Intercooler / Meth / Both: FMIC only w/P-1SC, FMIC + Meth with turbos
18k miles with a P-1SC and the last 7k with twin garrett GT3071r's.
Rick
Old 06-07-2009, 04:26 AM
Rickys S/C Z28's Avatar
mine was les then a year but it was my fought
Old 06-07-2009, 09:00 AM
rufretic's Avatar
DD or Garage queen???GQ
what psi you ran???14
What was the RPM's did you run it up to???7250
How many miles (aproximately)???1500
Less than a year / 1 year / 2 years / 2 years + ????less than a year
How "SAFE" was your tune???tune was good, "SAFE" isn't an option with stock bottom end and 14psi lol
Intercooler / Meth / Both ???fmic
My car was not driven on the street much but I did take it to the track a bunch which is going to beat on it a lot more than the street anyway. It could have lasted 2+ years on the street if I wasn't making wot blasts to 7000+rpms every time I drove it, but I was shooting for a 9 second pass with the stock block and stock 4l60e. It was the high rpms I was reving it to at the track that killed it. Even though it didn't last long with that kind of abuse, it did hold up very well to what I was throwing at it. 680rwhp with 20+ low 10 second passes with a stock 346 and stock 4l60e. I think that's impressive no matter how long it lasts, the stock 346 was just not built to take that kind of abuse but I'm still amazed it went before the 4l60e. The pass it blew up on would have been my first 9 second slip but it blew before the finish and still got a 10.1 at 131 and the pass before that I blew the launch but trapped 138. The vid is still fun to watch:
Quick Reply: How long did your stock ls1 last with boost????
