how hard is it to swap heads
Im geting a set of prc stage 2.5 5.3 heads soon with my stock cam and ive heard swaping heads isnt to hard just takes time and ive been under the hood many time just not to much with internal engine and the only thing im nervious about is torqueing the heads i saw how they do it on ls1howto but is that the right way has anyone else done it differently? Thanks
Follow that guide, take your time, and you should be good to go. Why not install a cam at the same time?
heads are not hard at all if you take your time! The hardest part of doing a head swap is getting the 2 ground bolts undone on the back side of the drivers side head. Other then that, its pretty easy sailing.
The biggest thing is to make sure you get ALL the coolant out of the head bolt holes !!! if you dont you will crack your block when you put the new bolts in. I like to take out the block coolant plugs, one on either side of the block. gets alot of the coolant out of the top of the block.
