Need headgasket help!
Old 06-22-2009, 09:36 PM
xtremejimmy's Avatar
Default Need headgasket help!
Helping a friend put together his 383 and we are just about done, but he isnt sure what head gasket to use. He has a ls1 stroked to a 383. I assumed the bore is the same as stock since it was only honed? I am right? Would it use i guess a stock GM MLS gasket? He intends to run some boost between 15-20 lbs i believe. Let me know what gaskets it needs so we can order them already.
Thanks.
Old 06-22-2009, 10:15 PM
conan's Avatar
What cc size is the heads.
Old 06-22-2009, 10:19 PM
LS1MCSS's Avatar
http://www.sdparts.com/product/COMC5...eadGasket.aspx
Old 06-22-2009, 10:26 PM
405HP_Z06's Avatar
Which heads are you using?
Old 06-23-2009, 08:27 AM
he is using untouched afr205's. It was originally used on his stock engine.
Old 06-23-2009, 03:40 PM
so a 3.910? What about a 3.905? which would be better for him. Trying to help him get his car on the road so I can be done helping on this project.
Old 06-23-2009, 04:59 PM
XtraCajunSS's Avatar
With those heads and that boost level, the GM MLS gaskets will be fine. You will need 2 of PN 12589226. We have them here: http://www.thunderracing.com/catalog...&sid=353#P2438
Thanks,
Shane
Old 06-23-2009, 08:59 PM
is that the stock headgasket size?
Old 06-24-2009, 10:26 AM
Yes it is, the bore size on those gaskets are more than adequate for both your heads and block.
Shane
