TEXAS SPEED Summer Short-block Sale!!!
With race season in full swing, We have a variety of 408 Iron, 402, 418, 427 Aluminum, and 454 LSX motors in stock and ready to ship right away! Each short-block is priced to include the engine crate and cradle. The only additional cost will be the actual freight charge to your door!
Feel free to PM, Email, or Call any TSP sales representative for shipping quotes or with any questions or concerns you might have!
Short-block on sale include:
408 6.0L Iron Short-blocks
-GM 6.0L Iron Block, Eagle Crank, Eagle H-beam Rods w/ ARP 2000 Bolts, -2cc 4.010 Bore Wiseco Pistons w/ Total Seal Stainless/Napier Ringset: $3600
-GM 6.0L Iron Block, Callies Compstar Crank (58X), Compstar Rods, -8cc 4.005 Bore Wiseco Pistons w/ Total Seal Stainless/Napier Ringset: $3700
***Pricing does not include the LS1 to LS2/LS3/LS7/LSX conversion kits. Add $300 you need a conversion kit with the short-block for your application!***
402 LS2/L76 Aluminum Short-blocks
-GM 402 LS2/L76 Aluminum Block, Eagle Crank, Eagle H-beams w/ ARP 2000 Bolts, -3cc 4.005 Bore Wiseco Pistons w/ Plasma-moly Ringset: $3900
-GM 402 LS2/L76 Aluminum Block, Eagle Crank, Eagle H-beams w/ ARP 2000 Bolts, -2cc 4.010 Bore Diamond Pistons w/ Plasma-moly Ringset: $3975
-GM 402 LS2/L76 Aluminum Block, Eagle Armour-coated Crank, Eagle H-beams w/ ARP 2000 Bolts, -3cc 4.005 Bore Wiseco Pistons w/ Plasma-moly Ringset: $3950
418 LS3 Aluminum Short-blocks
-GM LS3 Aluminum Block, Callies Compstar Crank, Compstar Rods, -4cc 4.080 Bore Diamond Pistons w/ Total Seal Stainless/Napier Ringset: $4900
-GM LS3 Aluminum Block, Callies Compstar Crank, Compstar Rods, -4cc 4.080 Diamond Pistons w/ Plasma-moly/Napier Ringset: $4805
427 LS7 Aluminum Short-blocks
-GM LS7 7.0L Aluminum Block, Eagle LS1 Crank (24X), Eagle H-beam Rods w/ ARP 2000 Bolts, -4cc 4.127 Bore Diamond Pistons w/ Plasma-moly/Napier Ringset: $5525
-GM LS7 7.0L Aluminum Block, Eagle Armour-coated LS1 Crank (24X), Eagle H-beam Rods w/ ARP 2000 Bolts, -32cc 4.125 Bore Wiseco Pistons w/ Plasma-moly Ringset: $5500
454 LSX Iron Short-block
-GM LSX Iron Block, Eagle 4.100" Crankshaft, Eagle H-beams w/ ARP 2000 Bolts, TSP Exclusive 4.200 Bore Diamond Pistons w/ Plasma-moly Ringset: $5500
Thanks!
Texas Speed & Performance
Thanks!
454 shortblock?
How much of a weight difference is there between the 454 an the 427. also about how much spray will they handle safely. 2. what heads would u recomend for each, all out street/strip killer. Thanks, Phil. Can u do a 440 for the same deal as the 427?
LS1Tech Premium Sponsor
You just need the $300 conversion kit to run the 402 in an LS1 4th Gen F-body.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Moderator
What's included in the conversion kit?
I may have some of the parts. A friend of mine blew his 402, and still havs the front cover and valley cover. Not sure what else he has or what I need.
Also, what is shipping to 06374 Plainfield CT
If it's cheaper, I could also get it delivered @ work for a businedd drop off. 06360 Norwich CT.
Dave
Dave
Could you sell the ls7 for $5k? How much (reasonably) will it cost to have the LS7 427 Aluminium completely built with cam, heads, accessories etc everything? What your BEST-EST price?
Dave
Dave
PM Sent on the shipping.
I'll see what we can do on heads guys. I know they are currently $75 off retail though!
sspower23: I don't think we can go that low on the 427. Shoot me a PM on what you are looking to put on the long-block as far as head options, gaskets, ARP or GM hardware, etc. and I will see what a full long-block would run you.
Thanks!
Thanks!
