Check out my New AFR 205 Heads
Look very closely at the curve. The valve train is going unstable at 6,000 RPM. This is a common problem with those springs as they have a harmonic at 6,200 RPM (got that information directly from Crane). Since you are going with the 8019's that should go away after the heads are installed.
Hey dude forget you and your heads. If Isee you I'm gonna kick you so hard in the nuts your head gonna pop off. J/K Congrads. What size pushrods did you have for your head and cam with the stock 241 heads? I just bought a set of 241's that's been ported and milled .016 with PRC dual springs and a 226/228 .585/.588 LSA 112. I hope I'm close to the 400 hp mark.
hey dude forget you and your heads. If isee you i'm gonna kick you so hard in the nuts your head gonna pop off. J/k congrads. What size pushrods did you have for your head and cam with the stock 241 heads? I just bought a set of 241's that's been ported and milled .016 with prc dual springs and a 226/228 .585/.588 lsa 112. I hope i'm close to the 400 hp mark.
