How can i tell if its a ford 9inch??
Old 06-26-2009, 08:52 AM
FBGSU02's Avatar
Default How can i tell if its a ford 9inch??
my grandpa has a 1976 f100 with a 390 in it and he passed away many years ago and now my grandma wants to get rid of the truck so i was going to part it out. i know the motor is a 390 but how can i tell if its a ford 9inch??? i looked online and some sources say it is. but is there a sure way of knowing?
Old 06-26-2009, 09:22 AM
Duffster's Avatar
take a few shots and post up here. OPINION>>> If it's got a 390, then its probably got a 9"
Old 06-26-2009, 09:32 AM
FBGSU02's Avatar
ok will do thanks, that is what i was thinking..
Old 06-26-2009, 09:37 AM
deelong4002's Avatar
if it doesnt have bolts in the back like a traditional rear end, than it is a 9". Correct me if im wrong?
Old 06-26-2009, 10:11 AM
FBGSU02's Avatar
can i convert this to fit my WS6?
Old 06-26-2009, 11:04 AM
Duffster's Avatar
Doesn't the 8.8" have bolt alignment similar to the 9"?
Old 06-26-2009, 12:32 PM
98silvertacrbn's Avatar
Not true a ford 8" looks like a 9" but smaller
Old 06-26-2009, 12:34 PM
8.8 cover bolts are on the back like a 10 bolt
Old 06-26-2009, 12:40 PM
Yes you can but it will need new bearing ends a torque arm mount f-body brackets welded on,and it will need to be narrowed since it coming out of a ford truck. I think the ford truck rears were about 2" wider then a f-body. The only way for me to know fr sure if it's a 9" is there will be no dimpels in the rear where the ring gear sticks out and the two lower 3rd member bolts right below the pinion you can't remove with a socket only a wrench
Old 06-26-2009, 12:46 PM
Here ya go some good info in here
http://www.maliburacing.com/ford_9_i..._nine_inch.htm
Old 06-26-2009, 02:03 PM
FBGSU02's Avatar
Thanks that was awsome info. Where do I begin? Where can I buy this stuff? Do I buy gm parts?
Old 06-26-2009, 07:50 PM
moser would be my first guess
Old 06-26-2009, 10:01 PM
Duffster's Avatar
meant the 8" Thanks
Old 06-27-2009, 07:37 AM
BADD SS's Avatar
Its a 9" I have a 1974 Ford f100 with a 360/4 speed.
If you have an f250/350 then it got a Dana 60
Old 06-28-2009, 09:41 AM
FBGSU02's Avatar
Here are some pics
here is one of the 390 it fired right up, it is dirty but runs great i was shocked.
Old 06-28-2009, 10:43 AM
01ssreda4's Avatar
you should put the 390 and the 9 inch in your TA.
Old 06-28-2009, 11:04 AM
FBGSU02's Avatar
i would like to but i think i am going to sell it and help out my grandma get some money out of it.
but does that look like a ford 9 inch????
