How can i tell if its a ford 9inch??
my grandpa has a 1976 f100 with a 390 in it and he passed away many years ago and now my grandma wants to get rid of the truck so i was going to part it out. i know the motor is a 390 but how can i tell if its a ford 9inch??? i looked online and some sources say it is. but is there a sure way of knowing?
Yes you can but it will need new bearing ends a torque arm mount f-body brackets welded on,and it will need to be narrowed since it coming out of a ford truck. I think the ford truck rears were about 2" wider then a f-body. The only way for me to know fr sure if it's a 9" is there will be no dimpels in the rear where the ring gear sticks out and the two lower 3rd member bolts right below the pinion you can't remove with a socket only a wrench
