Whining noise after H/C install
I have had a whine noise since I install my heads, cam, YT rocker and pulley. It sounds like a very quiet geardrive, happens through out rpm range. It sound pretty cool realy. But it has me concerned.
Could it be normal, I have not heard any other LS1s with a cam or YT rockers?
These are my ideas, waterpump bearing, Alt. bearing, Idler pulley or maybe just normal noise for the yella terra rockers. any thoughts.
__________________
2001 TA M6 Black
ENGINE: Absolute Speed Stage II, TR224/114, YT 1.7 Rockers, Katech oil pump & Jwiss chain, Shaner S2 TB, ASP pulley, Lid, FTRA, 160' Stat.
__________________
2001 TA M6 Black
The install was a few weeks and around 100 miles ago, I don't drive the car much, I can not tell if it is coming from the front of the motor or under the valvecovers. it is hard to hear at idle I need to rev the motor a little to hear it above all the other noises(sewing machine, ticks, knocks ect.)
It is inbetween a whine and a whistle sound. Anyone else have any thoughts????
Also I was thinking of taking the drivebelt off and starting it to see if it is internal or a belt driven accesory such as the waterpump. Is there anyway I could hurt the motor running it with out the belt for 10-20 seconds??
Originally Posted by bambamz
Did you ever fiqure the noise out? I have a H& C with YT's and am having the same issues..
No I hav'nt, I did pull the belt and the noise is still there so it is internal. Some day I will pull the YTs and put the stockers back in just to see if it goes away.
Well so far here is what I have done:
Pulled the belts, and checked all pulleys and pumps....No Luck!
Pulled the intake (since I have the Holley) and regasketed, and re RTV'd...No Luck!
Pulley the valve covers and reshimmed all YT's...No Luck!
Funny thing is at cold start..I dont hear it for about 3 mins...Then it starts and goes with the RPM's????
I have no clue but its driving me nutz...
99Z A4 with PP Stg 2, Big Cam, YT's, Holley Intake, ASP UDP, 80mm TB, all suspension bolt ons. 3500 Yank, 3.73, And afew others....
By chance do you have a ported TB? I originally had the stock unit on when I did my installed my heads. To get a little more air into the engine to compliment the heads - I add a ported TB and right away noticed the whistle. It would eventually go away as the motor warmed up but it was very present at first.
Just an idea.
Just an idea.
Actually I have the 80mm BBK...Mine doesnt whistle from a cold start but begins to once temp get to around 140ish. I think it might be my IAC. I have heard from a few sources that if they go bad they whistle
Any update, Have you figured out what that noise is?
i SURE DID! Part of the noise was the IAC which I replaced. 60 bucks.
The other part was my Polished Holley Intake. When I reinstalled everything I re-RTV sealed the Intake to header area but forgot to seal the Intake access panell underneth with RTV. Once it warmed up A leak would begin( due to the expansion of metal. Problem for me now solved. Thanks for your help.
