LCA Relocation Bracket Question
Old 06-30-2009, 01:47 PM
xXxSilveradoxXx's Avatar
Default LCA Relocation Bracket Question
Yesterday I started installing the laundry list of suspension mods I've accumulated for my car. While I was under my car installing other items I looked over what I would have to do to install my LCA Relocation Brackets. I noticed that I have to remove and cut a brake bracket. I only looked it over quickly but I couldn't see how to remove it completely. I'm not 100% sure on how to remove the brake line that goes through the bracket. This is what I'm talking about.
I figure when I take the tires off today and look at it from a different angle it will become obvious. The thing is I figure I'd make up a quick thread just in case it isn't obvious. That way I wont have any snags along the way.
Old 06-30-2009, 01:51 PM
35thLE02's Avatar
I have this same problem. If i cut the bracket, how am i suppose to hang the ebrake cable?
Old 06-30-2009, 02:03 PM
I believe the bracket goes on each side of the LCA mount. If you cut one side off you'll still have the other side.
Old 06-30-2009, 02:09 PM
Big_Bird_WS6's Avatar
sorry but what relocation brackets you have?
they look a little different. they look welded up instead of being bent and nice.
Old 06-30-2009, 02:13 PM
Damn it! I posted this in the wrong section. Could a mod help me out?
I have the UMI bolt on ones. That picture is off of UMI's site. The UMI Relocation Brackets are real nice pieces!
Old 06-30-2009, 02:21 PM
35thLE02's Avatar
+1 those are the same ones i have.
Old 06-30-2009, 02:22 PM
Xsta Z 28's Avatar
I cut part of my bracket off, with no issue.
Old 06-30-2009, 02:42 PM
5.3LJimmy's Avatar
I just cut the brackets with a 4" angle grinder without removing them. That way I don't have to deal with bleeding the brakes, which would be required if you removed the line.
Just put the bolt in from the outside hole without going all the way through. Take a pair of channel locks and bend the bracket back to where it is clearing the corner of the existing control arm mount and cut the unneeded portion off.
Old 06-30-2009, 03:34 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Thats one clean ride..
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 06-30-2009, 04:03 PM
Thanks bro for moving my thread, that's a clean *** ride!
Sounds like the plan! I guess I'll just clime under there with the grinder and get stuff done!
Old 06-30-2009, 04:13 PM
transampimp's Avatar
Does that bracket need to be cut on LT1 cars? I didn't have any issues on my car. It did take some work getting the bolts to slide through.
Old 06-30-2009, 04:37 PM
Xsta Z 28's Avatar
Exclamation
Thank you! Just a few BMR parts down there . . .
Oh, and this was the install guide I used:
http://www.installuniversity.com/ins...sity/index.htm
Old 07-01-2009, 08:47 AM
did my post get deleted? or did it not post.
Old 07-01-2009, 10:04 AM
Engine_HP's Avatar
are these SLP jounce bumper spacers ?
Old 07-01-2009, 12:37 PM
z28bryan's Avatar
I've typed out a post about 3-4 times this month and then forgot to hit "post". Getting older is great.
Old 07-01-2009, 12:40 PM
HA! Whenever I make a long post my computer freaking freezes, it never fails.
Old 07-01-2009, 01:17 PM
z28bryan's Avatar
On huge long posts, I often use notepad and save then copy and paste. Too many times have I hit "post" and then gotten the "couldn't find page.." error.
But anyways, back on topic
Old 07-02-2009, 09:33 AM
Xsta Z 28's Avatar
Yes. Came on all SS's that way.
