what rockers is best for TSP 231/237
Old 11-13-2003, 09:59 AM
tzshaheen's Avatar
Default what rockers is best for TSP 231/237
hi
i will go for the TSP 231/237 cam ... so im wondering.... what rockers will work with it :
1)1.7
2)1.8
3)1.85
and tell me wich brand please
Old 11-13-2003, 10:20 AM
Y2KSS's Avatar
I used the stock rockers with no problems.
Old 11-13-2003, 10:25 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Stockers or another 1.7 unless you plan on flycutting pistons.
Old 11-13-2003, 10:26 AM
WicketMike's Avatar
im using stock
Old 11-13-2003, 10:44 AM
gomer's Avatar
Stock or 1.7 aftermarket ones. I'm running the Yella Terra 1.7's with mine. The Yella terra's, TSP231/237 cam, and the Comp 918 springs make for a surprisingly quiet valvetrain. Much quieter than my old dual spring setup.
Old 11-13-2003, 12:22 PM
LSX Mechanic
Damian's Avatar
Most definately stock. Anything higher and you're going to bring that cam a good bit over .600 lift. Not good for springs..
Josh
Old 11-13-2003, 12:29 PM
cyphur's Avatar
Definitely stick with stock ratio. YT's are a great investment, for peace of mind. Stock will live for quite a while but HAVE broken under the right circumstance(spun well over 6k constantly).
Old 11-13-2003, 05:16 PM
tzshaheen's Avatar
i had a TR 224 with stockers but im going to get the TSP 231 with PP stage II ls6/lq9 heads .................. so i think it will bee fine going for a higher ratio but i need a good valvetrain sooooooooooo wich one to choose?
i need more poooooooooooooooooooooooooooower
Old 11-13-2003, 06:04 PM
jrp
SN95 Director
jrp's Avatar
take your pick of lifts
1.7 = .598/.595
1.8 = .663/.630
1.85 = 651/.648
as you can see, the stock rockers are your best bet
Old 11-13-2003, 08:08 PM
PlainwhiteZ28's Avatar
put some 1.8s so you can screw your heads, pistons, and whole motor up!
stick with 1.7s..........
