New Era Performance and 440 rwhp!!!!!
Old 07-25-2009, 02:06 PM
GM01SS's Avatar
Talking New Era Performance and 440 rwhp!!!!!
Some may know that my motor went BOOM!!!!!in May!
Had the guys @ NEW ERA PERFORMANCE install a new LS6 long block with a NEW ERA SSHT Cam and American Racing Headers, along with a grocery list of small items ( ported oil pump, double roller timing chan, underdrive pulley etc.).
To say I am satisfied is a HUGE understatement. Mike kept telling me, the number is going to change, the number is going to change........well it did, it got better!
Final results........................440 rwhp
........................................409 rwtq
A special "thanks" to Mike and Justin and all the others @ NEW ERA.....
Anybody that may "think" the numbers are bit off,I was there when the car was on the dyno and saw every pull.
top notch work guys!!!!!
Gary
Old 07-25-2009, 02:16 PM
IRONFIST's Avatar
Well what was done to the LS6? Did you stick with the stock 243's?
Old 07-25-2009, 02:19 PM
GM01SS's Avatar
The LS6 is completely stock other than the NEW ERA cam. Heads are stock and untouched!
Gary
Old 07-25-2009, 06:08 PM
studderin's Avatar
wow gary, thats some power
whats size? 1 7/8 ARH?
thats with your LS6 intake, ported stock TB, GMMG right?
Old 07-25-2009, 07:01 PM
97ta383's Avatar
What are the specs on that cam? Awsome numbers by the way!!
Old 07-25-2009, 08:17 PM
GM01SS's Avatar
Yes..all of the above...........
Old 07-25-2009, 08:19 PM
GM01SS's Avatar
For those interested.......SSHT cam 228/232 111 LSA
Old 07-25-2009, 09:38 PM
transaman98's Avatar
that is pretty impressive. I would be interested to see what it does at the track.
Old 07-26-2009, 06:14 AM
GM01SS's Avatar
May do a pass or 2 this year. Car is used primarly for roadracing @ Watkins Glen International!
Old 07-26-2009, 07:52 AM
vettett15's Avatar
You're right I don't know if I believe that. I know a guy with a z06 that got those numbers with your mods (except a G5X3!!) and that was considered very good. Are you sure Jesus was not running on the rollers?
Old 07-26-2009, 08:23 AM
GM01SS's Avatar
Wink
For a comparo.........same car same dyno......4/07 364rwhp 369rwtq
65 degree weather. 29% humidity
7/09 85 degree temp.....29% humidity...........440rwhp 409rwtq.
So you decide.........I was there, no tricks, no bu//chit...those are the numbers and YES I'm sure that JESUS was there!!!!!!
Old 07-26-2009, 08:34 AM
blownws6_nc's Avatar
congrats, Mike and the rest of the guys know there $hit.
Old 07-26-2009, 09:02 AM
vettett15's Avatar
I attached the z06 dyno graph I was referring to (keep in mind it is in STD). Are you planning on bringing it to the track anytime soon, that will reveal whether or not you are making that kind of power assuming you can hook up, etc.
File Type: pdf
Old 07-26-2009, 09:11 AM
Fb0dy0nly's Avatar
I had a cam that was the same size in my 346. it was advanced a few degrees tho, fun as hell to drive around in the 3-5k range. Whats the lift on the cam?
Enjoy the new found power!
Old 07-26-2009, 01:43 PM
GM01SS's Avatar
Ben.......nice set up..........I don't have the ability to download the run.....however Mike from NEW ERA certainly does!
We started out with a base of approx. 400 rwhp and it kept getting better as adjustments were made.
I also used the American Racing 1 7/8 w/o cats.
Gary
Old 07-26-2009, 01:44 PM
GM01SS's Avatar
Lift is 600
Old 07-28-2009, 10:50 PM
Mike @ New Era's Avatar
No dyno tricks, common, you guys should know me by now, 7 years here on this forum, search high dyno numbers from New Era. I know it is surprising because we are known for having low dyno numbers and fast track times, but this is what it made, no BS, he is just happy about it. He doesn't drag race, but I guess he will see who is passing who at Watkins Glenn in the straights! Tricks don't happen on the dyno here, they happen when we build your car...
Old 07-28-2009, 11:17 PM
studderin's Avatar
that its a high dyno, me and mike put a brand new unported FAST92 and a NW92 TB on my car a few weeks ago, and I only put down 413whp. But I went 123.9mph #3350 the next day at NYIRP.
People overlook the all the little things in the LS6 motors and 243 heads There almost 10 years old now too. I took a pic today at the shop for you gary
