compression with 317's and mls?
I have a stock bottom ls6. I want to put the 317 heads I have on to lower compresiion abit while I build my 6.0 block. how big (thick) can I go with a mls gasket. I know I cant get the compression to low with head gaskets. but with 317's and a thicker head gasket how low can I get it. I would like to get down to 9.2:1 if its possible.
thanks
thanks
i have used a couple of different compression calculators and some show 9.6 and some show 9.8. how much boost do you plan on running?
http://www.race-cars.net/calculators...alculator.html
only thing left to figure out is if ls7 lifters are taller then ls1 lifters. if there the same I dont have to get different pushrods.
