Spec Me out a torquey cam pls
Old 07-31-2009, 02:14 PM
sspower23's Avatar
Default Spec Me out a torquey cam pls
Can some spec out the Torquiest cam for a set of PRC LS6 stg 2.5 cnc ported heads? With all the power from Low-Mid range RPM pls, thnx
Old 07-31-2009, 02:29 PM
NemeSS's Avatar
the LPE GT11 cam is very responsive. even for its low duration, it is very aggressive
Old 07-31-2009, 02:51 PM
MelScrilla's Avatar
the lift on that cam is crazy for such a small cam, I would like to see a dyno on that.
Old 07-31-2009, 03:23 PM
Tough Mudder
Hilton's Avatar
https://ls1tech.com/forums/lsx-parts...orquer-v3.html
Old 07-31-2009, 03:44 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
What short-block and bolt-on mods do you have? That'll help us recommend a camshaft that fits your combo best!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-31-2009, 03:51 PM
01ssreda4's Avatar
another vote for the torquer v3, awesome cam and it pulls hard.
Old 07-31-2009, 04:32 PM
NemeSS's Avatar
ive used this cam in a 346 ls1 and in a 370, both with stock heads and dam does it pull hard wot, during normal driving, u would think its the stock cam
Old 07-31-2009, 05:56 PM
chrs1313's Avatar
isnt the lift pretty high on the tq3...i say go with something closer to what i have in my sig
Old 07-31-2009, 06:20 PM
Tough Mudder
Hilton's Avatar
Yeah, 644 intake lift. Great lobes though. Not as hard on springs as you would assume.
Old 08-01-2009, 12:44 AM
sspower23's Avatar
Ok the setup is 346 ls1, LS6 intake for now, PRC LS6 stg 2.5 cnc ported heads, pacesetter longtubes, ORY with cutouts, magnaflow exhaust, Strange 12 bolt rearend, 4.11s maybe 4.33s later.
So now whats the TORQUIEST CAM for this setup?? Whoever, Comp cams, Texas speed, Thunder racing, makes the torquest camshaft I will buy, cant wait anymore, Thnx
Old 08-01-2009, 01:17 AM
chrs1313's Avatar
already told you search my name and you will see one bad *** torque cam...look at 60ft times for proof
Old 08-01-2009, 05:28 AM
PREDATOR-Z's Avatar
231/227 .617/.614 110-1 lsa
That will give you what you want.
Strong trq 3000 rpm > peak
Peak ~6200 rpm, shifts ~6600
Power range 2200>6600+
9* overlap (nice rapid popcorn lope)
Old 08-01-2009, 12:36 PM
LS1crazy01's Avatar
I would love to hear what that sounds like!
Old 08-01-2009, 04:02 PM
PREDATOR-Z's Avatar
It will sound very similar to this:First with cutout closed then open
http://www.youtube.com/watch?v=LpU-CC5OOM0
Old 08-01-2009, 04:04 PM
NemeSS's Avatar
that sounds real good PRED
Old 08-01-2009, 05:06 PM
LS1crazy01's Avatar
Man I cant wait to get a cam!
Old 08-01-2009, 05:29 PM
chrs1313's Avatar
thanks...runs amazing too...
Old 08-06-2009, 09:58 PM
JimMueller's Avatar
I had good luck with a HR2127/HR2129 110LSA +2 spec'ed by Patrick G for me. That's a 227/235 .645/.650 110+2 on LSK lobes. I swapped it out because 1) a lifter damaged a lobe and 2) I couldn't get the valve control I wanted above 6400RPM. I miss it!
Old 08-06-2009, 10:32 PM
sspower23's Avatar
Damn I like the lift on that cam. Where did you buy from?
Old 08-07-2009, 10:29 AM
JimMueller's Avatar
Spec'ed by Patrick G for my then-current combo and ordered through Thunder Racing. I used Caddy Racing lifters with that cam, and switched back to LS7 lifters for the current cam.
Quick Reply: Spec Me out a torquey cam pls
