Thinking about a cam...
Im contemplating on putting a cam in my car but have a few questions first.Ive got a 00 WS6 with full bolt ons but the car hads 115,xxx miles...is this too many miles to think about doing a cam swap? If not whats a decent street cam set up? Ill be keeping stock heads and LS6 inatke, any help will be appreciated, thanks guys
look up the el torro specd by pred z its a 230/230 .612/.598 cam has worked well for many people. I would also get a ls2 chain, and a new oil pump along with springs, locks, retainers, puchrods, and a gasket/bolt kit.
Me and my buddy just put a cam in his 00 WS6 with 117xxx miles.We used the TR224 cam with a 114lsa and comp 918 valve springs.His car loves it.And the computer learned its self.
I did my h/c swap with 115k miles on the car. You'll be fine as long as you replace any wear parts like stated above as you do the build. The TR224 is a good street cam. Many people use it. You'd even like the TR 228R cam. Just depends what you want out of it.
anybody have any info on the T-Rex cam??? How street firendly is it? at what point will the stock rockers need to be changed with a cam? i know a guy with 00 WS6 m6 car with ls6 intake, lid, full exhaust and T-rex cam made 421hp at the wheels! does that seem high to anyone for a cam only car?? maybe not..maybe its a good cam tho
T-rex might be a bit too large for what you want, I run the 228R from texas speed. Great powerband from 3k to 6700, idles great with the 112 lsa. Has a nice lope to it and driveability is awesome. You would see around 35-40 hp for this cam.
yea i was thinking it might be too much for what i want...i dont dd my car but i do want to be able to drive wherever i want but still have a nice mean sound and get nasty when i want to
LS1Tech Premium Sponsor
We've seen tons of higher mileage cars get camshafts. I wouldn't let the mileage stop you from having a blast with the car. What converter are you currently running? this is a very important question. Also what power range are you looking to make power in? This will help us to use data we've put together from testing different camshafts to help spec you out the best possible camshaft for you application.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Also checkout my recent threads with different camshafts in the same engine for dyno testing. This will help you see power output from different durations to help make your choice easier!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
