Can I use N20 with my F1 cam (230/226 .591/.571 112)???
I have been thinking of going down that road for a while now and I don't really want to spray a big shot, just like a 75, maybe even just a 50. I know my cam is pretty much the opposite of what a n20 cam is supposed to be with the larger intake duration and 112 lsa but would it hurt anything to spray with the aboved sized shots? should i get my car tuned down a little if i do (custom mti tuning on there now). any input would be appreciated.
john
john
75 was almost unnoticable on my car back in the day, so a 50 might give you a slight edge if needed but not really worth the expense in my opinion. but i dont think it would hurt to spray on that cam. i spray on a tr224 112 and it works pretty good.
john
john
LSX Mechanic
Originally Posted by redz_02
you can use it, but from what i've heard they don't fully use a nitrous shot when compared to a traditional split cam.
josh
Sure, nitrous works good with ANY cam...it just works better with some cams. Spray it with a 75 shot and if you want more, spray it with a 150. IMO, you shouldn't worry about a nitrous specific cam unless you're going to spray a 200-250 shot or better.
I'll move this to the N2O section.
Originally Posted by Damian
This is true. Traditional split cams will generate much more TQ on nitrous opposed to a reverse split. However it won't "hurt" to spray that cam. You'll make roughly the same rwhp as a standard split would, and less TQ which isn't always a bad thing. Go for it..
josh
josh
Motor 410 RWHP
400 RWTQ
150 Shot 553 RWHP
Wet kit 583 RWTQ
How much more torque would I see with a different cam?
