383 Possibility?
Old 08-02-2009, 01:44 PM
Fast 95 Z28's Avatar
Default 383 Possibility?
Is it possible to make my 98 LS1 a 383? I read that my year block can only be honed .005" and you have to hone to .010"? I already found a forged rotating assembly kit from texas speed for $1,800. I plan on using a MS3 cam would this cam clear the connecting rods with a 4.00" stroke? Finally does anyone know how well the MSD ignition box would work with this 383 crank, because I have read about people having problems with aftermarket cranks and the MSD.
Thanks
Old 08-02-2009, 03:19 PM
come on guys i know some of you have built 383 LSx motors before
Old 08-02-2009, 05:52 PM
2001_ws6's Avatar
Well, first off let me start with that I am not an expert concerning the engine blocks. With that being said, im not sure who told you that .005" is the most that you can do, but 3.905 is the most common bore used for the 383 rotating assembly. 3.898 is stock so .007" hone...practically nothing.
As far as PTV you should be completely fine. The MS3 was meant to clear stock pistons, and likely if you purchase a rotating assembly from texas-speed the pistons will have some sort of valve reliefs built in. Since texas speed carries both why not call and ask? Also ask a local shop to look at the block for the whole honing part...youll need to anyways.
And the MSD I havent the slightest clue.
Old 08-03-2009, 12:36 AM
does anyone know how much you can hone a 98 ls1 block?
Old 08-03-2009, 12:58 AM
97ta383's Avatar
Why would you want to use a msd ignition box? The stock igntion system would be fine with new plugs and wires. Im pretty sure the block needs to be honed out a little bit to fit the 383 and its defintly a good idea to have a machine shop clean it up as far as that year block being different i havent heard about but i would call texas speed since you are ordering parts from them they are very help anyway.
Old 08-03-2009, 01:09 AM
ZMONSTER!'s Avatar
Search man.
You cant bore an LS1 like the blocks of old. 3.905 is generally accepted as the max safe bore size. throw a 4 inch stroke crank and you have a 383.
From the sounds of it your LS1 isnt heavily modded? Id say don't stroke yet, use that money to buy the best heads you can possibly afford (ahem mamo AFR's) and then get a cam to match those heads, not cam first. do a good H/C build and you will probably make more power than a stock 241 headed 383.
Old 08-03-2009, 11:26 AM
MelScrilla's Avatar
Originally Posted by ZMONSTER!
Search man.
I agree with this. This is what I plan to do. Look into building a H/C stock bottom end motor. By the time you finish this you will have all the bolt ons, an LS6 or Fast intake, and a good H/C setup. This will make anywhere from 420-450rwhp which is real nice. When your ready for a 383 reuse the same parts and you'll be looking at real close to 500rwhp if not more with killer torque.
Old 08-03-2009, 08:08 PM
I want to use the MSD ignition because I dont have the LS1 PCM i bought the motor as a long block for $1000. Does anyone know if this kit http://cgi.ebay.com/ebaymotors/TSP-3...Q5fAccessories would work well with stock heads and a .605/.609 238/240 112 Degree cam when it comes to piston to valve clearance and cam to rod clearance?
Old 08-03-2009, 11:31 PM
MelScrilla's Avatar
call texas speed they are a sponsor. they can tell you more and order the kit over the phone so you know exactly what you are getting.
Old 08-03-2009, 11:37 PM
ZMONSTER!'s Avatar
Id definitely recommend that you read around here ALOT more before you buy anything. You need to figure out what is out there and what you want from the car. Dont just look at LS1tech either. there are other sites out there (like hardcore) where alot of what is taken for gospel here is not so highly regarded.
Old 08-04-2009, 12:04 AM
blackn2oss's Avatar
take my word like zmonster said get u a good set of heads and a cam to match it before stroking it! i had a 383 with set ot tsp 5.3 stage 2.5 heads and a cam ground for those heads and u could feel the power restriction!!!! and as far as block ive tried all year models and cracked all year models but i was pushing a lot of nitrous down it throught LOL!
Old 08-04-2009, 02:55 AM
14 Second Truck Club
Hemi Killer's Avatar
I did alot of research on the bore topic before ordering stuff for my 98' LS1 block. The 97-98 sleeves aren't as thick as the later blocks. The max safe bore is 3.903" on a 98' block. I think a few people on here have taken it to 3.905", but I'd rather be safe than sorry. I got the Mahle pistons (-6cc Valve reliefs) and Scat Rods for Texas Speed, good sponsor!
Btw, 383 make awesome torque down low and in the midrange! Especially with the F13!
Old 08-04-2009, 06:01 PM
thanks for your input hemi killer. do you think i would still be able to use this same set from tsp if i only bore to 3.903? would there still be enough room for the pisons to expand? i really want a stroker ls1 i dont care if its a 380 or w/e c.i. rater than a 383 . .002 of an inch isnt much
Old 08-05-2009, 08:26 PM
blackn2oss's Avatar
the biggest thing u will run in to is getting a 3.903 piston with out buying a expensive custom build. i may be wrong but i dont remember seeing a shelf build 3.903. 3.905 is a common shelf piston.
Old 08-06-2009, 01:52 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
Thanks
I believe max bore per GM is .010 per side......020 total diameter (that's three sheets of copy paper thick!). The sleeves are usually .060 thick and are supported by the aluminum casting around them. I know of folks punching these LS1 blocks .030 over (.015 per side) cleaning up cylinders that ate a ringland/piston from a previous failure.....no issues.
These blocks aren't paper thin and fragile as delivered from the general. Just set it up with a 3.905 or 3.910 (also common) and don't give it another minutes thought....you will have zero reliability issues.
Hope this helps....
-Tony
Old 08-06-2009, 02:14 PM
fastvet's Avatar
...Good words Tony, but also, you might want to think about just getting a short block 383 from texas speed instead of building one. It sounds cheap the way you are doing it, but once you get the labot into it, its gonna cost you pretty close to an assembled forged 383 that TSP has already. Cuz if your going to stroke it, then you dont want to go with pistons that arent forged. Just food for thought...
Old 08-10-2009, 12:47 AM
i don't see why the labor would cost me so much. the only thing i will be paying for is the bore job to 3.905. i'm going to build the engine on my engine stand in my garage.
Old 08-10-2009, 08:04 AM
fastvet's Avatar
you also got to pay to hone and balance it. Go talk to a machine shop before you get fully commited to this and find out what the total cost is going to be for you, then go from there. Just trying to help out bro...
Old 08-10-2009, 09:24 AM
david vericker's Avatar
The man already stated that he needed to pay for the cylinders to be bored (honed) and the rotating assembly can be purchased as balanced unit.
Eagle was making a forged stock LS1 bore size piston when we did my 383 back in 07. This would require only a very light hone (cylinder clean up) and would allow for the expansion of the forged pistons in the cylinder. Obviously this will be a 382,thus you will lose a "whole" one cubic inch.
Old 08-10-2009, 07:56 PM
I just saw your car in your sig and u have a 98 ls1 block. u didnt resleeve the cylinders for the 3.905 bore did u? i'm just wondering how the motor was running if u bored the stock sleeves. all i'm going to be using the motor for is drag racing. ya and i'm going to purchase the 383 rotating assembly from TSP so it comes balanced already.
