Any APS guys running a catch can between the breather hose and inlet duct?
you run it from the valve cover front nipple on passenger side in between to where the line goes into the side of intake . Those other lines are inlets from the air intakes. I am thinking not running those at all just breathers on my valve covers those hoses all over the engine compartment are so cluttery. You can get think a small breather to put on drivers side valve cover that will go into factory grommet and you can buy breather that go on passengerr side and replace oil cap. Then just run catch can in between remaining line from passenger valve cover to intake and that should do the job.
I did but the car was still pulling oil into the intake through the catch can (AMW). It was doing a good job and seperating the majority of the oil but my intake was still coated in oil after only a couple hudred miles... Once i plugged up the lines, no more problems...
Here is my setup now...
https://ls1tech.com/forums/forced-in...pinions-2.html
And yeah that line straight from the nipple into the intake looks like it would pull oil mist.
This is a great read and explains why i didnt want to just run breathers.
https://ls1tech.com/forums/generatio...v-systems.html
Yea, the APS reccomendation is to run the passenger side valve cover (rear vent) to the drivers side intake pipe. Then to run the drivers side valve cover vent to the passenger side intake pipe.
The front vent in the passenger side valve cover is then routed to the stock location but you replace the OE check valve with the one APS provides.
Is there anything custom other than moving the accumulator?
The only problem besides moving the accumulator was i still havent found a good place to mount the baffled breather tank, the thing is huge. This is an easy fix, though.
I wonder if you could merge the two lines into a catch can before they reach the inlets.
I'm running almost the same setup as you Cobra Commander and I'm actually about to put two catch can's on the TA. For the mean time I have two breathers (one on each valve cover). Ill make sure to throw some photos up, should be done next week. On a side note Im assuming your running no cats does your setup burn oil a little bit or that's just me?
