02 Z06 cam?
Old 08-07-2009, 05:54 PM
ta-stanger's Avatar
Default 02 Z06 cam?
Well guys, im looking into getting a cam. My car's a DD so i don't want major lope but still a decent 30 hp gain?
A buddy of mine just sent his 98 firehawk off to get a MS4 cam, and took his old 02 Z06 cam taken out .218 intake, .204 exhaust .550 lift, and 117.5 lobe sep. The cam only has 7k miles on it and came out of an LS6 crate motor. He's wantin to sell it w/ the pushrods, lifters, and springs for lil over 200$.
What kinda gains do you think i could get from this cam? Is it worth the money for a DD cam or should i go a lil bigger ( like a .228 cam?)
Old 08-08-2009, 07:52 AM
SweetS10V8's Avatar
Make sure the cam has #5308 on the back of it. Ive seen tons of people selling "LS6" cams that arent.
Old 08-08-2009, 08:55 AM
bigti99a's Avatar
i am not a cam expert but i am sure a lot of people will tell you there are a ton of great aftermarket cams that will be better and not hurt the DD factor. its pretty much all in a good tune.
Old 08-08-2009, 09:16 AM
puggerton03's Avatar
it doesnt sound like your buddys giving you a very good deal.
Old 08-08-2009, 10:27 AM
MikeG's Avatar
I'm not real sure about 30 hp, probably 20-25 would be more like it. The consensus on here though is that if you're going to go to all the trouble of swapping cams, go with an aftermarket one. Why gain 25 hp when you can gain 50+?
Old 08-08-2009, 10:37 AM
Hugger's Avatar
I did that swap a long time ago and couldn't feel any real noticeable gains. I would advise against the swap unless your buddy wants to give you the package for free.
Old 08-08-2009, 11:17 AM
ta-stanger's Avatar
Ok thanks guys...yeah i was thinkin the same thing...i just didn't know the gains.
Old 08-08-2009, 02:58 PM
SCM_Crash's Avatar
Get a TSP 224 or 228R cam instead. It's not going to lope crazy at all and it's going to make more power. LS6 cam is pretty much going to be lame without the 243 heads. You'll make more power using stock heads with a 224 or 228R.
Also, for $200, it's not worth it at all. A new cam is often times around the same price. If you're going to go through the trouble of installing a cam, get a new one that makes more power.
Old 08-08-2009, 08:15 PM
Blk_Ws6's Avatar
He's said dd I guess you'll never get the right answer but Thank God I did the swap to:
I had ls6 cam an heads only I upgraded to a 224 cam and didn't feel a difference at all Man the ls6 package is a Dog for real I don't even have headers but if you get the ls6 Heads,Cam, an Intake without headers you'll kick *** but with headers you'll really be glad you went down that road.
Old 08-08-2009, 08:18 PM
Blk_Ws6's Avatar
^^^ Forgot to add you'll see mid 12's NO ONE WILL NO WHAT YOU HAVE an how you doing it all my buddy's thought I was spraying them Ls6 cam, heads ,intake headers 3000 stall an you might hit 11's
Old 08-08-2009, 09:17 PM
Moderator
jimmyblue's Avatar
The LS6 heads are worth more than the LS6 cam,
look at some of the other "old man" cams or a
220 or 224 on 114. The only good thing about LS6
is you won't need to tune it, because it does almost
nothing to how the motor runs. So what's the point,
when most of the cost is in the labor?
Old 08-09-2009, 10:03 AM
Blk_Ws6's Avatar
I totally agree but alot of us f-body lovers hate having to go trough all of that so we do it simple and our setup still make good numbers an still be daily driven.
Old 08-09-2009, 12:08 PM
92SilverSHO's Avatar
I know my car is a DD, but when you don't have a tuner anywhere close by and i mean within 300 miles or so. Its a pain so i can see why people do ls6 heads/cam.
Old 08-09-2009, 05:21 PM
Blk_Ws6's Avatar
Same reason why I'm doing it my car still have factory cats an exhaust.
Old 08-09-2009, 07:55 PM
lsxmalibu's Avatar
I had an edelbrock cam and changed over to the ZO6 cam and love it. Doesnt pull as high rpm wise but 2500-6000 it pulls like a train. and if you run full exhaust it’s a short-duration design with low overlap so it’s
not really affected that much by back-pressure
Old 08-09-2009, 09:14 PM
Siciliano15's Avatar
for people with 98-99 ls1's which have the bigger factory cam, they can add some 1.8 rockers to their car and end up with almost identical cam specs as a 2001 corvette ls6 cam. this along with the ls6 heads and intake should bring u to the 385hp rating of the corvette in 2001. 2002+ ls6 cam was a little better.
Old 08-10-2009, 01:53 AM
Quik Sand's Avatar
Id say your gain would be closer to 20
Old 08-10-2009, 05:48 PM
ta-stanger's Avatar
Ok so im done looking at the ZO6 cam. Any recomendations?
Old 08-10-2009, 05:52 PM
jetlag's Avatar
GT2-3 by Lingenfelter.
207 / 220
.571" / .578"
It works with LS6 springs..
Old 08-10-2009, 05:56 PM
codysgto's Avatar
tsp 224 on a114 lsa
