C6 Corvette 6speed into 97 TransAm?
Old 08-11-2009, 06:01 AM
roger97ta's Avatar
Default C6 Corvette 6speed into 97 TransAm?
Does anyone know if a 6 speed out of a C6 Corvette can be used in a 97 TransAm 6 speed car? If so what other parts are needed to make it work?
Thanks for any responses.
Old 08-11-2009, 06:25 AM
85MikeTPI's Avatar
No. Vette's use Transaxle versions of the T56, they won't mount directly behind a motor without major mods. The internals can be mounted on a GTO mainshaft and installed into an LS1 Fbody T56, but the C5/C6 units are not direct swaps.
Old 08-11-2009, 09:44 PM
stdgrabbag's Avatar
yea i just had one done, and it takes alot more parts to make it fit
Old 08-11-2009, 10:55 PM
the_merv's Avatar
About the only thing they are worth to an F-body is the extra parts. If you have a MN12 or GTO T56 then you can get some different Gear Ratios out of them.
Old 08-12-2009, 08:15 AM
thesource's Avatar
If you can pick it up cheap, it might be worth spending the money to convert it.
Old 08-12-2009, 08:35 AM
85MikeTPI's Avatar
In re-reading the OP, I see that he mentioned a 97 Fbody, which would be a LT1 car. So even if the C5/C6 -> Fbody T56 conversion was done, in this case it still wouldn't help..
Old 08-12-2009, 08:51 AM
thesource's Avatar
You might be able to machine the input shaft down to fit the LT1. I've never done it or even compared the two inputs side by side.
Old 08-12-2009, 09:29 AM
85MikeTPI's Avatar
LT1, LS1, C5 (double-cone)
Machining the LS1/C5 input down to LT1 dimensions would lose 60% of the clutch splines and would be almost impossible to make work.. The CTSv input comes closest to doing this, but even then you lose 20% of the splines.
Old 08-12-2009, 09:59 AM
the_merv's Avatar
Good pic.
Quick Reply: C6 Corvette 6speed into 97 TransAm?
