forged 347.. how strong is it?
I found a good deal on a stock ls1 block. I am wanting to build a engine right now and Im kind of thinking about doing a 347, I am going to do a good set of rings, rods and pistons in it. The car will be on a 200 shot also. Just wondering what type of power you guys are making on this setup. Also what is the max power you think my block could handle? I figure on running a decent cam, it will be 24x's durations and stage 2.5 5.3 heads.
Should I not do this and look at going more towards a lq9 or 4?
thanks for any input guys...
Im really wanting to run low 10's on the car...
Also, am I stupid to do this on a 98 block, I know they dont have as much meat on them, but i figured I could atleast get it to a 347 right? If not theres another block I can purchase, its just the 98 was pretty cheap.
I plan on making ~750 RWHP from my setup.
1998 LS1 Block
Stock Crank
Callies Compstar Rods
Wiseco 2618 coated pistons
ARP hardware (studs whever applicable)
Clevite 77 H Series Bearings w/ Durabond Cam Bearings
Stage III Heads
Boost
You should certainly be able to make 10 second power out of a forged 347, just make sure you have a good controller for that nitrous and you should be fine.
1998 LS1 Block
Stock Crank
Stage III Heads
Boost
LS1Tech Premium Sponsor
I've made over 850rwhp on my TSP 347cid short-block without any problems. We offer compete rotating assemblies, if you decide to build one give us a call! I bet we can help put together a nice combo for you!!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Thanks for the help guys. I have a decent controller right now, so im not too worried about that. Also my car is going on a diet, Ive already lost a few things on it now.
I like what everyone is telling me, from the looks I think the forged 347 will work great for me. also jason ill give you a call, and see what you got.
I made 580 rwhp when I lived at sea level on my forged 347 from TSP. Now I'm at 520 rwhp at 5,600 feet elevation, on 11 #'s of boost. This winter I'm going to a smaller pully and some meth to brake the 600rwhp mark. The bottom end doesn't worry me one bit. A 200 shot won't be a problem... Hit it with a 300 shot
