80# injectors to much for my 383 build?
Old 08-14-2009, 06:07 PM
vipvegas's Avatar
Default 80# injectors to much for my 383 build?
I have been looking for a used set of 60# injectors and have run across a buddy of mine who has a set of 80's he will give me that work. Will this be to much for my 383 stroker sts build. I have a walbro 255 in tank.
Old 08-14-2009, 06:19 PM
vipvegas's Avatar
Also these are high impedence will this work?
Old 08-14-2009, 07:03 PM
Yelo's Avatar
Depending on the boost levels you see they may not be enough....
Old 08-14-2009, 07:26 PM
vipvegas's Avatar
Enough most guys are running 60's in there 402 setup. Why would you say that Im going to shoot for around 12psi
Old 08-14-2009, 08:50 PM
cablebandit's Avatar
those injectors should be fine and will support more than just that one walbro will
Old 08-14-2009, 09:52 PM
vipvegas's Avatar
should I add a second walbro or whats the next step up pump?
Old 08-15-2009, 12:17 AM
DeltaT's Avatar
+1. Maybe add a 2nd walbro with a Hobbs switch.
Jim
Old 08-15-2009, 12:25 AM
vipvegas's Avatar
definately dont want the fuel to be the downfall of producing higher numbers.
