Electric Fans a Must?
I am pulling parts together for a custom made front mount turbo setup, and would it be a good enough investment to buy new electric fans for engine bay room?
Don't know what kind of turbo setup you are doing or your plans for your radiator but if you have the room use the factory fans,they are hard to beat.Most likley though you will have to go to aftermarket fans to get the room you need.Keep it a puller setup if at all possible,they are much more efficiant than pushers.There is lots of good info on here about radiator and fan setups.Someone can probably hook you up with a link but one good thread is"those that stood the radiator up and vertical" or somthing close to that.
We have the OEM GM radiator 52466004 in stock for $254.74
and also an aftermarket unit Spectra Premium in stock CU1486 for $142.29.
Sprectra is a great product so I would not hesitate to go with that unit if price is an issue.
these are both Z28 with LT1 engine for 1995 Z28
Hope this helps
Oehq
Hope this helps
Oehq
