I need help on my car?
Old 08-23-2009, 12:21 AM
draklon13's Avatar
Exclamation I need help on my car?
Ok all of a sudden when im on the highway and go i pass 70 mph my car starts shaking ( mainly from the front left and right side of the car) and when i go faster it gets worst and my steering wheel starts to shake also, i feel like my car is going to break apart and make me crash. this started a week ago, and now im geting fed up with it. i use to go past 70, **** all the way to the max with no problem now i get this awful sensation all over my car shaking the hell out of it plus the steering wheel. i also hear alot of metal rattling to once i go over 70 mph. when im under 70 it runs fine but as soon as i hit 70 all hell breaks loose, please help. i have a 2002 ss camaro
Old 08-23-2009, 12:24 AM
hitmanws6's Avatar
it sounds like your tie rods on the drivers side are messed up. id get the inner+outer replaced
Old 08-23-2009, 12:36 AM
draklon13's Avatar
Exclamation
ah! thats funny cause about a week ago i had the mechanic check me suspension to see if it was ok (6 month check up) and he did mention about a tie rode being bent on the driver side, but he did not tell me it was a major problem, but man it is, i hate that i can go pass 70 with out feeling about to crash.
Old 08-23-2009, 12:54 AM
hitmanws6's Avatar
then that mechanic must not know much. the tie rods are a crucial part of your steering system. that wobble you feel is your wheel rocking side to side. id say thats a major problem
Old 08-23-2009, 12:55 AM
draklon13's Avatar
do you know a good spot to get them at that are reliable and a good price? or should i head to good o cheap o wanna be lifetime warranty autozone?
Old 08-23-2009, 12:58 AM
draklon13's Avatar
when you say inner and outer, that means two parts ?
Old 08-23-2009, 12:59 AM
hitmanws6's Avatar
id recommend MOOG brand for the inner and outer, not sure if auto zone carries them
Old 08-23-2009, 05:16 PM
jimbo98z's Avatar
So you've been driving your car for a week feeling like you were going to crash at highway speeds?
Old 08-25-2009, 04:56 PM
draklon13's Avatar
yup lol
Old 08-25-2009, 04:57 PM
draklon13's Avatar
im going to replace the inner and outer rods tomorrow, but is it recomended for both sides?
Old 08-25-2009, 08:34 PM
jimbo98z's Avatar
If you do one side, might as well do the other. If one side has gotten that bad, then the other isn't going to be like brand new.
EDIT: Also, are you 100% sure that's the problem, or at least part of it? Throwing parts at a problem can get expensive and frustrating, just ask me how I know
Old 09-02-2009, 09:35 PM
Muscle Freak's Avatar
tie rods? ehh maybe.... i'd replace those anyways, if one is bent for sure. but check wheel balance on the front wheels, as well as wheels bearings on each side. Also, check your tires, visually you will see a separated belt, but anything else in the tire you might not notice...
