Is C16 the best bet for race fuel?
Old 08-25-2009, 04:00 PM
theblur98ss's Avatar
Default Is C16 the best bet for race fuel?
Just curious what everyone is running as far as race fuel is concerned. Most of my driving will be done on 93 but if I get the chance to turn it up at the track I plan to add race gas. Is C16 the best bet or is it overkill for my setup? I'll be running a 9.3:1 408, 91mm turbo at a max of 20psi or so. I don't really want to mess with meth.
Old 08-25-2009, 04:33 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
how much power you plan to make?
how quick do you plan to go?
are you running bs3?
Old 08-25-2009, 04:44 PM
kp
kp's Avatar
Its the most readily available and safest option, unfortunately its also the most expensive.
cablebandit's Avatar
c16 will be perfect. It does well with hot IATs and you will have to lean your tune some on it. On my car it likes 12.0 afr
Old 08-25-2009, 05:10 PM
WAHUSKER's Avatar
It killed my O2s, so I've decided to run pump gas & meth. Just not worth the few extra ponies to me. If I ever do feel the need I'll run Trick 101 or the new Sunoco 104 octane.
Old 08-25-2009, 05:15 PM
LS1Tech Co-Founder
A2A or A2W, 'nother question...
Old 08-25-2009, 05:26 PM
4" a2a, BS3. I'm guessing 900-1000rwhp and 8 sec capable. I've heard the bs3 sensor holds up a little better to c16 then the stockers.
Old 08-25-2009, 05:31 PM
kp
kp's Avatar
I get a long time out of BS3 sensors and C-16, well over a season. If you dont run your a/f at 10:1 or something they last a long time.
Old 08-25-2009, 06:21 PM
kdavis's Avatar
just a question what about ms109?
Old 08-25-2009, 09:17 PM
LS1Tech Co-Founder
900-1000rwhp you pretty much only want to run C16. I'd say if you were dinkin' around with 700-800rwhp you could see if 110 works for you.
Old 08-25-2009, 09:38 PM
6 Second Club Moderator
LASTLS1's Avatar
I wish you were closer, I'm sitting on about 125 gallons.
Old 08-25-2009, 09:55 PM
427's Avatar
Don't let anyone smoke around you!!
Kurt
Sorry, could not help myself.....
Old 08-25-2009, 10:07 PM
LASTLS1's Avatar
Kurt
Hey Kurt what's up? I can't wait until my cars running again so I can burn some of it!
Quick Reply: Is C16 the best bet for race fuel?
