7psi on stock tune??
Old 08-26-2009, 04:18 PM
KILLER-LS1's Avatar
Default 7psi on stock tune??
hey guys, i would like to be able to start up my car and check for leaks and everything before i tow it to a tuner, but can i at least start it on the stock tune with the stock injectors & walbro pump? im just going to let it idle. once i get to the shop, ill put in the 60# injectors..
also does anyone recommend a FI tuner in southern california??
Old 08-26-2009, 04:27 PM
stevied916's Avatar
well at idle no load it will be 0 psi but you should be ok with it just idling. I wouldnt try to drive it though
Old 08-26-2009, 04:31 PM
KILLER-LS1's Avatar
no i wont, at the most, it would be driving it up the car ramp, if even that...
Old 08-26-2009, 04:34 PM
ninetres's Avatar
You should be okay. Just dial the FP regulator to get the A/F close if you have heads/cam. If not, you should be fine if you stay out of boost driving up the trailer lol.
Old 08-26-2009, 05:34 PM
LQ9CHEVELLE's Avatar
Talk to Charlie @ RPM in Valencia, CA. He's mainly a corvette guy, but tunes everything GM. Has done lots of turbo @ supercharged tunes, and he stands behind his work. Nice guy also! PM me and ill send you his ###
Old 08-26-2009, 06:20 PM
1320's Avatar
Youll be fine moving the car around. For tuning you can try andy....(corvettes)
I was just down in the oc last week too. I could have gotten you atleast rolling.
Time to get a scan gauge.....tuner program, and a wide band maybe though...
Old 08-26-2009, 06:28 PM
IT_SS's Avatar
pm sent
Old 08-27-2009, 07:32 AM
lt170chevelle's Avatar
Yeah +2 on being fine as long as you arent giving too much gas and spooling up you will be fine.
Old 08-27-2009, 11:39 AM
Customizing Director
MadIceV8's Avatar
Why not just run the car without the belt installed?
Old 08-27-2009, 11:57 AM
jrcc2002's Avatar
Maybe the turbo doesn't use a belt.
Old 08-27-2009, 12:41 PM
98Camarod's Avatar
lol
As long as you didn't put a 2 bar map and not change the operating software you should be fine.
Old 08-27-2009, 12:46 PM
JonCR96Z's Avatar
There's a local guy that has a D1SC on his T/A and it has stock tune. The fuel trims are maxed out everywhere and he says it runs out of fuel at about 4500. Supposedly does about 8spi. He's been driving it like that for a year.
Old 08-27-2009, 03:23 PM
KILLER-LS1's Avatar
well looks like i need to run a 2 bar w/ speed density. so ill be trailering it haha
Old 08-27-2009, 04:20 PM
MadIceV8's Avatar
LMAO... my dumb comment of the year
Old 08-27-2009, 04:37 PM
KILLER-LS1's Avatar
haha its okay, i guess i didnt really say it was a turbo lol
Old 08-28-2009, 06:02 AM
jrcc2002's Avatar
It took me a while to figure it out too. The only way I knew it was because you said there was a turbo in the works in your sig.
Old 08-28-2009, 06:23 AM
EPP
EPP's Avatar
If you leave the stock injectors in it for now, you'll be just fine at part throttle driving. Bob
Quick Reply: 7psi on stock tune??
