Sponsored by: DashLynx
How to get Rubber/tar off paint
Old 09-02-2009, 01:05 PM
Z28Red01's Avatar
Default How to get Rubber/tar off paint
Got some burn out rubber and maybe some tar right behind my rear wheel, best way to get it off?
Old 09-02-2009, 01:16 PM
LS1RedZ's Avatar
I decided to try some westleys bleche white on mine. Sprayed it on, but didnt let it sit to long (not sure if it harms your paint) and then took the soapy wash rag and that stuff came right off. Or you could use Goo gone, but that **** likes to smudge.
Old 09-02-2009, 01:32 PM
ZaneO's Avatar
Stoner's Tarminator, WD-40, Goo Gone, etc.
Allow to dwell (but not dry). Gently rub to remove. Reapply as necessary. Make sure to re-wax the treated areas afterward.
Old 09-02-2009, 02:35 PM
LS14EVR's Avatar
I've used brake cleaner on my truck but not sure if I'd use on my baby.
Old 09-02-2009, 02:36 PM
Dirty Dog's Avatar
The commercial tar removers all seem to work pretty well. But if you spray some PAM on the quarter panel before doing burnouts, the rubber will hose right off.
Old 09-02-2009, 05:16 PM
Z28Red01's Avatar
Hm yea the Pam is a good idea never heard of it, have to remember it for Friday night at Cecil County
Old 09-02-2009, 05:26 PM
RICEETER's Avatar
wd 40 works fine for me
Old 09-02-2009, 07:36 PM
InTheHawk23's Avatar
PAM LOL THATS AWESOME but the bug and tar is probably the best to get it off good luck
Old 09-02-2009, 08:12 PM
transam5.7lt1's Avatar
Use a regular coca-cola..... it works....
Old 09-02-2009, 08:26 PM
Havok2's Avatar
Acetone works good
Old 09-02-2009, 11:38 PM
tspence45's Avatar
I've used Acetone and Mineral Spirits. They both work damn good.
Old 09-03-2009, 12:27 AM
pir7tr's Avatar
clay bar
Old 09-03-2009, 02:23 AM
mediocrels1's Avatar
ive used gas nd its worked
Old 09-03-2009, 09:43 AM
EATSGTS's Avatar
I've always used gas on my stuff, just a little bit on a rag. Then wash with soap and water, and put some wax back on it.
Old 09-03-2009, 12:15 PM
pjb
pjb's Avatar
if seen acetone strip paint clean off. be careful
Old 09-03-2009, 01:55 PM
-98-Z28-Darkness-'s Avatar
any bug and tar remover from autoparts.
Old 09-03-2009, 02:26 PM
|2ocky's Avatar
I would just start out with all purpose cleaner and a bug sponge. It should easily take off the tar after a couple minutes and then u can try it on the rubber. If the rubber doesnt come off then id start looking at more powerful options like rubbing compund.
Old 09-03-2009, 02:35 PM
bracketracerZ28's Avatar
Acetone works great as long as you have a clear coat paint job. Takes a lot off, you will just need to buff the area after as it will haze
Old 09-03-2009, 03:04 PM
Z28Red01's Avatar
All great ideas thanks guys, hell I'm exciting to try coke. Be interesting if it does work and I can avoid any real chemicals.
Old 09-03-2009, 10:07 PM
cbr600rx7's Avatar
Very hard on the paint. It might not be the end of the world if you just wipe it right off but i would not let it set for more the a second or two.
Quick Reply: How to get Rubber/tar off paint
