what heads to get ??
Old 09-05-2009, 01:12 PM
overkill-lt1's Avatar
Default what heads to get ??
ok iam looking for some heads for my ls1.i cannot afford afr dart or edl. with that being said. what heads and from who .i have about a 1500 budget. let the fun begin
ls1, ls6 intake 80mmtb,1.75 headers, 30 svo injectors cold air intake
Intake Duration at 050 inch Lift 222
Exhaust Duration at 050 inch Lift 224
Duration at 050 inch Lift 222 int./224 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.566 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.568 in.
car weight 2720 lbs
thanks
Old 09-05-2009, 01:27 PM
ThaBirdWS6's Avatar
prc stage 2.5 5.3L heads are the best bang for the buck out there
Old 09-05-2009, 01:37 PM
ZMONSTER!'s Avatar
Not really.
OP look around your area for a good head porter. I found a local one in my area that can get ~310cfm out of 241's with stock size valves for less than a grand. There's talent all over the place not just on tech.
If that's not an option how about some 243's with a good VJ?
Old 09-05-2009, 01:42 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
Originally Posted by ZMONSTER!
Not really.
i'd like to see the port volume of that head, and actually see it flowed on an independent bench and see flow though all the lift ranges.
Old 09-05-2009, 02:14 PM
ZMONSTER!'s Avatar
hey dude whats up?
Ill see about getting some of the specifics for yall.
Upon further consideration the best answer for the OP is probably to save your cash for a set of AFR's/TFS's. I went budget and now I regret it.
Old 09-05-2009, 07:24 PM
garygnu65's Avatar
patriot heads jegs/summit $1300.
Old 09-06-2009, 09:53 PM
any opinons on patriot heads
Old 09-07-2009, 08:19 AM
Gen414's Avatar
First of all, car weight 2720?? What kind of car? Not an FBody, I know that, so...???
2nd..if you are limited to $1500, gonna have to pick up some ported stockers.
I agree with what another guy said a few posts ago.....save up a little bit more, and buy a set of AFR's or TFS....
Old 09-07-2009, 09:15 PM
f-bodyguy's Avatar
or buy a set ofnew l92 for like 500 a peice and then all you need is rockers that are like 6 bucks a peice...thats what im going to do....you need a new intake but you can buy an ls2 intake for less then you can sell your ls6 for......and they flow awsome stock....im sure there are going to be people argue with me but the guy that did my machine work has stock l92's with 918 springs and his car is a low 6 sec car i beleive
Old 09-07-2009, 10:03 PM
Red99TA's Avatar
pick up some used 243's on here and send them to TEA for a stage 1.5 or 2...it's maybe $200 over what you're looking to spend though. PRC 5.3 or LS6 stage 2.5's are used pretty commonly on here too for budget builds.
Old 09-07-2009, 10:41 PM
ZMONSTER!'s Avatar
I didn't think l92 heads fit on ls1, need 4 inch bore. I've never seen anyone describe an ls2 intake as awesome either.
EDIT do you mean ls2 243's? Cause a cathedral port ls2 intake may have issues on a rectangular port head...
Old 09-08-2009, 07:14 AM
its an rx7
thanks for the input
Old 09-08-2009, 10:28 AM
allngn_c5's Avatar
Never ever , ever go cheap on heads. Save for the best heads you can get that fits your goals. Next get a custom cam that is matched to your heads and then you will have a well thought out combo.
I personally was cam only, (g5x3) and then added afr 205's. I would've been so much further ahead of the game had I picked a custom cam that was matched to the heads.
If you do get a custom cam, keep in mind that there is no reason to run more lift then what your heads will flow to. (.640 lift cam with heads that don't flow beyond .625 for example)
