A/C Pulley
Old 09-07-2009, 07:46 AM
blackz28x07's Avatar
Default A/C Pulley
Last night I drove through a deep puddle that was hard to see. At first all my gauges dropped and my check gauges light came on. I pulled over immediately and turned the car off. After a minute I tried to start it and everthing was fine. Well a couple minutes later I started to smell a burning smell. I was near where i was going so when i got there I opened the hood and saw my A/C pulley was red hot. It only gets this way when I have my A/C or defrost on. Could water have gotten into the pulley and mess up the bearings enough to where the pulley has so much friction it gets red hot?
Old 09-07-2009, 07:49 AM
fleetmgr's Avatar
Unlikely. More likely is you just lost your compressor.
Old 09-07-2009, 08:15 AM
Well it still blows out ice cold air for the minute I have the a/c on, that's why I didn't think it was the compressor. If the compressor was bad, would it really make the pulley get red hot? Everything is still spinning like usual. I also forgot to say there's a metallic sound when the car is running.
Edit: Forgot to add another thing. It was my a/c clutch pulley that was red hot. Sorry
Old 09-07-2009, 12:45 PM
I was just told my another LSx member that if the compressor needs a recharge it can make the A/C clutch slip and get really hot. How would water effect the compressor?
Old 09-07-2009, 05:11 PM
So does anyone know anywhere I can get a compressor for a decent price?
Old 09-07-2009, 08:15 PM
Schnell's Avatar
Are you serious... it is 'red' hot almost like a brake rotor?
Old 09-07-2009, 09:05 PM
Yep, it was crazy as hell. Right when i saw that i turned my car off and it cooled down.
Old 09-07-2009, 09:16 PM
eseibel67's Avatar
Here's my guess:
Even when it's cooling, a compressor is very hot. The deep puddle cooled it very quickly, and changed the shape of the pulley/clutch/case.
Now the clutch is slipping like crazy causing the heat as well as the metallic noise.
You might get away with a clutch only, but I would replace the whole compressor due to the trauma it has suffered.
Old 09-08-2009, 09:32 PM
Schnell's Avatar
This is my guess too. Clutch has to be slipping and causing the brake rotor effect on your compressor.
Old 09-08-2009, 11:05 PM
LS6427's Avatar
blackz28x07,
Bro....are you talking about the pulley that is attached to the compressor....or one of the other two smaller pulleys that the a/c belt runs around?
Old 09-09-2009, 08:48 AM
Originally Posted by LS6427
blackz28x07,
The one connected to the compressor. I'm just going to go ahead and replace the compressor and clutch.
Old 09-09-2009, 03:59 PM
Schnell's Avatar
Can the clutch itself be replaced?
Old 09-09-2009, 05:27 PM
I can't find anywhere that sells just the clutch. I went ahead and bought a used compressor and clutch off a member on the site. At least I haven't had to use the a/c or defrost this week haha.
