LS6 ported oil pump vs SLP oil pump
Old 09-09-2009, 01:22 AM
sspower23's Avatar
Default LS6 ported oil pump vs SLP oil pump
Which one is better, more durable and performs best - LS6 ported oil pump Or SLP 'Heavy duty' oil pump Or is there one better out there? Thnx
Old 09-09-2009, 01:58 AM
deadmanTA's Avatar
Idon't know about best I went with.the ported ls6. Gained about 10-15 psi. I'm very pleased w/ it for $100.
Old 09-09-2009, 04:17 AM
kdavis's Avatar
where did you find a ported ls6 pump for 100? the cheapest i have seen is 150
Old 09-09-2009, 06:54 PM
wickedbluess's Avatar
Tsp ported and shimmed ls6 oil pump here, great oil pressure.
Cold start 60psi
Idle 48psi
Wot 80+psi
My bro has the slp and its 35psi @ idle. They say it depends on the spring you put in the pump.
Old 09-10-2009, 11:24 AM
KRAZY K 2000 TA's Avatar
Cold start 60psi
Idle 48psi
Wot 80+psi
mine is the same and i took my ls6 pump out and went for the slp only to have 40 psi wide open so i pulled the pump last night and took it apart whatever moron put it together left part of the casting flange in the bypass valve stuck under the seat, i wont by an SLP again
Old 09-10-2009, 09:56 PM
TTA1437's Avatar
Is there a way to tell what spring you have?
What needs to be checked so you have optimum psi?
Old 09-11-2009, 06:54 PM
After seeing my bros psi i wouldnt put that pump in my car. But also some guys say dont get cought up with oil pressure, 35psi is normal for an slp pump.
From what i've read/heard the slp pump comes with three springs i think. then depending on the spring you put in gives you your psi from low to high. I'm pretty sure a sponsor or slp can help you with finding out what spring you have in your pump.
Raul
Old 09-11-2009, 08:47 PM
Red99TA's Avatar
I wouldn't worry too much about pressure as long as it's at least 30's at hot idle. I ported the discharge side of my stock LS6 pump and reused the spring and it's low 30's at hot idle and high 40's I think at WOT (not real sure as I haven't checked it at WOT lately). I don't know about the SLP having 3 springs...doesn't make much sense to me as just 1 "long" spring fits in there. Also the pressure is completely dependant on the spring alone.
Quick Reply: LS6 ported oil pump vs SLP oil pump
