Should I descreen MAF for FI setup??
Old 09-09-2009, 07:55 PM
vipvegas's Avatar
Default Should I descreen MAF for FI setup??
Check the sig. Tuner wants to keep maf in place, should I at least descreen it. This baby is a virgin as of now??
Old 09-09-2009, 08:48 PM
dschmittie1's Avatar
Are you at least doing an SD 2 bar tune and still using the MAF? And how much boost do you plan on running. If you plan on running much more than 10#s I would ditch the MAF and find someone that will do your SD Tune. Jeremy Formato did my SD tune car runs great and he is based in Florida
Old 09-09-2009, 09:50 PM
sujomatt's Avatar
Yea i dont think ull b using a MAF with that kind of power..
Old 09-09-2009, 10:33 PM
vipvegas's Avatar
A reputable tuner on here told me that they would rather me keep MAF in, Im using former STS kit piping.. But he did say SD tune.. Im putting a 2 bar map sensor in..
I mean engine is pretty stout, next will be the rear end Ill drive it till it goes. So I think 700+ could be easily obtainable on high boost and 500+ DD on the street..
What ya think on the tune?
Old 09-10-2009, 06:07 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Follow your tuner's advice.
Old 09-10-2009, 06:10 AM
sujomatt's Avatar
Wait I am not following.. He told you to do either? Or?
Old 09-10-2009, 07:04 AM
Jontall's Avatar
I was scared when I first went to a SD tune, but I've been running it for 2 years now with great results. Get rid of the MAF and get a speed density tune.
Old 09-10-2009, 07:31 AM
moehorsepower's Avatar
Mine...722 RWHP with a stock MAF less screen because I was one of those on the band wagon in the early years about removing the screen..OK let the rock throwing begin
Old 09-10-2009, 07:47 AM
94z28lt1's Avatar
honestly the maf is gunna hold you back just get rid of it if you want to see the potential of your setup
Old 09-10-2009, 07:51 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
Still running a screen in my maf over 600rwhp.
Old 09-10-2009, 07:58 AM
LS1Tech Sponsor
Slowhawk's Avatar
I'd leave the screen in it.It does help alot when tuning a FI car.For a Turbo setup I would go SD with no MAF BUT you can tune with the MAF if you like.
Old 09-10-2009, 08:16 AM
I have access to a dyno for a whole day, so when the build is complete I will tune it with the maf and get all data, then right there on the dyno, remove
the maf and re tune to see how much I will actually gain, or has anyone ever done this?
Old 09-10-2009, 10:28 AM
vipvegas's Avatar
See the impression he left was to leave MAF and SD tune it... Im confused now will have to call him to get this straight.
Quick Reply: Should I descreen MAF for FI setup??
