proper mounting of 5 point harness
Did you buy bolt-in or wrapped?
In my case, I bolted the hip straps to the stock seatbelt mounting points on the floor
then wrapped the shoulder straps around the rollbar using the provided brackets.
My submarine belt wrapped around a mount I bought from Wolfe.
i use 1/4 thick metal, prob a lil overkill but its fine.and i just cut a piece of plate that you would use for a rollcage and welded that to the floor then welded this on top of it.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
chvypwr31 has them mounted how most NHRA techs would like to see them. Reasoning is if you got in an accident and the belts pulled tight, the tabs won't bend like that. But if you mounted them flat to the floor, they could bend 90 degrees.
Derek
Derek
