Drag Racing Tech
proper mounting of 5 point harness
Old Sep 14, 2009 | 02:49 PM
transamsam98's Avatar
Default proper mounting of 5 point harness
anyone know what the regulations are for mounting the 5 point harnesses? also where and what to use to mount them? I just need to double check before mounting them
Old Sep 14, 2009 | 04:36 PM
James Montigny's Avatar
Did you buy bolt-in or wrapped?
In my case, I bolted the hip straps to the stock seatbelt mounting points on the floor
then wrapped the shoulder straps around the rollbar using the provided brackets.
My submarine belt wrapped around a mount I bought from Wolfe.
Old Sep 14, 2009 | 04:40 PM
cambirdracing's Avatar
did mine the same except the crouch strap. I used the bracket the belts came with, 1/2 bolt and drilled a hole in the floor with a 2" sq 1/8 thick plate under the bottom of the floor.
Old Sep 14, 2009 | 11:45 PM
chvypwr31's Avatar
heres how i mounted mine -tony-
Old Sep 14, 2009 | 11:46 PM
the belt is a gforce latch n lock non wrap around and it recomends that it pulls straight and not angled wich was my worry about using the stock bolts/ mounting points
Old Sep 14, 2009 | 11:52 PM
chvypwr31's Avatar
thats why i did mine the way i did, i didnt like the huge angle the right side lap belt was if it was bolted straight to the stock mounting point on the floor. -tony-
Old Sep 15, 2009 | 12:35 AM
does it pass inspection? thats my bigest concern btw thats exactly how I was thinking of mounting mine
Old Sep 15, 2009 | 02:02 AM
chvypwr31's Avatar
i havent had my car teched yet but i talked with bill stroud himself and told him of my idea cause i have never seen it done like that and he said no problem.
Old Sep 15, 2009 | 02:03 AM
chvypwr31's Avatar
and i got a bunch of seat belt tabs already made up for future jobs so if you want a few just let me know.
Old Sep 15, 2009 | 02:21 AM
I think I have enuff scrap let over to take a stab at it but thank you for the offer and pictures and advice
Old Sep 15, 2009 | 02:24 AM
chvypwr31's Avatar
let me know if you want dimensions.
Old Sep 15, 2009 | 02:26 AM
dimensions would be great and im sure helpful to others as well as myself
Old Sep 15, 2009 | 02:27 AM
chvypwr31's Avatar
i will get them up tomorrow
Old Sep 15, 2009 | 08:57 AM
csjta2's Avatar
I would also like dimensions, maybe a better pic as I also do not like the angle of the right side using the factory bolt location
Old Sep 16, 2009 | 01:59 PM
chvypwr31's Avatar
i use 1/4 thick metal, prob a lil overkill but its fine.and i just cut a piece of plate that you would use for a rollcage and welded that to the floor then welded this on top of it.
Old Sep 17, 2009 | 11:34 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
chvypwr31 has them mounted how most NHRA techs would like to see them. Reasoning is if you got in an accident and the belts pulled tight, the tabs won't bend like that. But if you mounted them flat to the floor, they could bend 90 degrees.
Derek
