Removing e-brake cable from rear
Old 09-15-2009, 06:15 PM
99ccz28's Avatar
Default Removing e-brake cable from rear
My ebrake cable has a spring on it and I can not seem to get it off the hook on the back of the brake assembley. Any tricks to this? Thanks!
Old 09-15-2009, 07:23 PM
99Bluz28's Avatar
Make sure the parking brake is off(disengaged).
If you can get some slack in the cable it'll be a lot easier!
Then use a Adj. wrench to help pull the spring back.
Old 09-15-2009, 07:38 PM
Platinum WS6's Avatar
if the e-brake is not up you should be able to push it forward off the hook...put some man on it
if you cant get enough man on it then get some channel locks or something to grab it and pull it off the hook
Old 09-15-2009, 07:42 PM
99ccz28's Avatar
The spring prohibits me from pulling it off. The spring is very stiff. I guess ill just keep trying.
Old 09-16-2009, 07:22 AM
Save the manuals!
wssix99's Avatar
Why are you trying to take it off? (Its a lot easier to do if you are working on the e-brake mechanism at the time.)
There is an easy way to get it off without wrestling the spring. (Kent-Moore has a special tool for this, but I recall it being $100.) The catch is that if you slip, you may have to go in and rebuild the e-brake mechanism.
Old 09-17-2009, 12:16 PM
99ccz28's Avatar
I am pulling the rear.
Old 09-18-2009, 07:24 AM
Save the manuals!
wssix99's Avatar
If you do the vice grip thing and can get the spring back off the lever, you can undo the two screws holding the small frame that holds the lever to the back plate. That will allow you to pull the lever out slightly and angle it out of the attachment, but...
The other end of the lever that you can't see has a socket that engages a push rod in the e-brake mechanism. If it disengages the rod, it may be difficult to get back in there unless you completely disassemble the e-brake and put it all back to together.
Old 06-15-2018, 04:38 PM
01CamaroSSTx's Avatar
Received 1,787 Likes on 1,294 Posts
Old thread revisited while doing a search on how to remove this. Thought I'd help those who may be searching on how to do this so here it goes.
No special tool is needed just proper use of a flat head screwdriver on the prongs while pulling on the cable until it comes out giving you enough of the cable to remove it form the brake actuator.
Quick Reply: Removing e-brake cable from rear
