Accufab 4 barrel t body for boost lsx
Old 09-15-2009, 09:28 PM
OUTLAWZ RACING's Avatar
Default Accufab 4 barrel t body for boost lsx
Has anybody used them on a vic jr or super vic in a z28? Im building a max effort car And was wondering if it work well with boost and yes it will be a huge ci motor and a fairly large frame turbo.
Old 09-15-2009, 10:14 PM
ninetres's Avatar
I think it woould work great in my un-expert opinion. Seems like it would distribute the air to each runned better. I always wanted to installl one right on top of the victor....with a 90* bend on top of it.
Old 09-15-2009, 10:17 PM
That is exactly what I want to do. The elbow works good but my thoughs are these throttle bodies and carb style intakes push 408-418 to 600 plus n/a so by being a max effort boosted lsx I should gain some. I just dont know tho.
Old 09-15-2009, 10:45 PM
MelScrilla's Avatar
a 4 barrel carb hat like procharger uses for their carb systems would work good for boost since the system is pressurized the little bend wouldn't be a problem.
I guess you already know with a big single plane and a 4 barrel throttle body your cowl and wipers may be in trouble. In a race car it doesnt matter much though.
Old 09-15-2009, 10:50 PM
Gingervitis Addict
slow67's Avatar
I would use an extreme velocity pro series carb hat. Meant for 1000+ hp.
Old 09-15-2009, 11:20 PM
DanZ28's Avatar
Persoannly, Im not convinced there is anything to gain over an elbow and a 105mm FI TB yet, but would sure like to know if there is one, it looks cool too.
Two options I was looking at:
carb hat http://www.smreperformance.com/index.html with http://www.moranmotorsports.com/prod...roducts_id=101.
Or one of these http://www.prolineraceengines.com/ca...19c82a02e866b5 with http://www.moranmotorsports.com/prod...roducts_id=162.
Old 09-15-2009, 11:35 PM
ninetres's Avatar
Your first option looks like a sharp bend, and the second option seems to elimiate the benifit of directing airflow directly to each runner. Just my observations. I would opt for the 4 barrel TB right on the victor.....with a longer CLR 90* bend on top of it!
Old 09-16-2009, 03:35 AM
Jimmy P's Avatar
Thats basically what my new setup is. Accufab 4150 TB, ported/polished Jr Vic manifold, with a Extreme Velocity carb hat. Haven't got it running yet.
Old 09-16-2009, 03:43 AM
jmill96Z's Avatar
I was kind of wondering the same thing. I'm already running an Accufab 4150 setup on my nitrous huffer, but was wondering how it would work for boost.
Old 09-16-2009, 06:54 AM
Firechikn's Avatar
How well will the hat seal with just the one bolt. I'm thinking of doing a blow through, or t boby on the next project. Just don't know how much boost it can take.
Old 09-16-2009, 08:01 AM
Shawn @ VA Speed's Avatar
the accufab 4150 tb is by far the best setup for a fi carb style intake setup.It has WAY better airflow distribution that an elbow could ever dream of.The sacrifice is hood clearance.
Old 09-16-2009, 09:24 AM
1CAMWNDR's Avatar
Victor Jr, Accufab 4150 and a Spectre carb hat fits under the stock hood, well a VFN flat hood anyway.
Old 09-16-2009, 11:34 AM
DanZ28's Avatar
Same hat about 90% of blow thru's are using out there now, look at Denny Savages old car, it works. I'll need a 6" cowl to put a longer bend on it. Second option, same thing. I'm a tall deck BBC, gotta make **** work and the second option is most likely gonna be it. A 4 brl TB and hat will add 8+ inches on top of the manifold using the hat in that link.
Old 09-16-2009, 03:12 PM
Jimmy P's Avatar
Do any of you guys recommend using something like this as well? I called them and told them about my setup and they recommended a 2" tapered spacer. They said these spacers do a lot more than just increase the plenum volume.
http://www.wilsonmanifolds.com/shop/...uct_detail&p=9
Old 09-17-2009, 04:05 PM
TT350's Avatar
Don't buy a Accufab!
http://www.theturboforums.com/smf/in...topic=131746.0
Old 09-17-2009, 05:33 PM
White.Lightning's Avatar
Originally Posted by TT350
Must be registered = no good
Old 09-17-2009, 06:51 PM
Jimmy P's Avatar
For those that aren't registered with that forum, he had a customer issue with Accufab. Not a actual problem with the TB. From reading that post I am not sure he even owned one of their products.
Old 09-17-2009, 07:30 PM
Is it on a 4th gen f-boat? If so how was fit ment
Old 09-17-2009, 07:36 PM
See thats what I see and hear. I seen cars with a elbow on a vic jr switch to a 4 barrel and pick up close to 30 hp across the board and tq. I dont work for any sponsers lol. But it just shows me that they out flow a elbow set up even with a 90/90 setup. Need less to say Im going for it lol!
Old 09-17-2009, 07:38 PM
DanZ28's Avatar
On an FI application?
Quick Reply: Accufab 4 barrel t body for boost lsx
