FINALLY got my new suspension in..
Old 09-21-2009, 12:14 PM
hoseman1553's Avatar
Default FINALLY got my new suspension in..
After months of online ordering from halfway across the world, i finally got home and had the T/A with its new suspension awaiting my open arms. I must say the handling has greatly improved and it sticks to the road like glue. The only downside ive noticed are those big *** dips in the interstate that you cant really avoid..
BMR springs
KYB adjustable shocks
UMI Panhard bar
UMI LCA and LCA brackets
UMI Torque Arm
UMI Strut Brace
Attached Thumbnails FINALLY got my new suspension in..-1.jpg   FINALLY got my new suspension in..-2.jpg
Old 09-21-2009, 01:51 PM
UMI Performance's Avatar
Good to hear!
And thank you for your contributions to the USA
Old 09-21-2009, 02:08 PM
Charlay's Avatar
Nice man.
Old 09-21-2009, 03:54 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Ride height looks great!!!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-22-2009, 11:01 AM
teke184's Avatar
really excited to get my bmr/kyb setup in....stance looks killer...i'm worried about being a little low for ME.
throwing around using the front 1/2" spacers from BMR and fabing something for the rear.
then i get a little less drop, but all the benefits of the stiffer springs.
Old 09-23-2009, 01:40 PM
i havent really had any issues with the fact of it being low, including speed bumps. However, in Northern Va along the interstate the roads are pretty crappy and they tend to be a excessively bumpy so that tends to make things difficult. My KYB's are set at 4 all the way around, im thinking about putting it up the next level or at least in the rear to see how that helps at higher speeds. Other than that, i love it and definitely like the improved handling. It makes for a fun drive on the country roads
Old 09-23-2009, 02:48 PM
BMR Tech2's Avatar
If you need those 1/2" spacers let me know. I have plenty in stock.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 09-24-2009, 06:14 AM
teke184's Avatar
my issue is i have TDs...
Old 09-24-2009, 06:56 AM
UMI Sales's Avatar
Hello
Did you think about doing the heater hose mod? That would drop the rear like 1/2 inch giving you enough room for your TD's. Just a suggestion for you.
Take it easy
Brad
Old 09-24-2009, 12:09 PM
teke184's Avatar
i know...but i want the stiffer springs too.
besides i already have the springs....
Old 09-24-2009, 12:14 PM
zach_ws6's Avatar
nice looking car. reminds me of my first one.
Old 09-24-2009, 06:12 PM
pewter2002's Avatar
What are these 1/2 inch spacers the BMR rep was talking about? I am interested in upgrading my susp too, but am concerned with going too low as well. Is there a pic available? Do they work with all springs? How much? Front only? Anybody have experience with them?
Old 09-24-2009, 06:41 PM
teke184's Avatar
they are for the front only
they mount under where the bottom of the shock/spring unit mounts to the lower A arm
they are $60 i think
should work with any spring..since they mount under the shock really
Old 09-24-2009, 08:05 PM
pewter2002's Avatar
Default spacers for front
Thanks, TEKE, I am in the same boat as you are! My current SLP/Bilstein set up rides well, handles well but but the rear end sag and softish dampers are getting to me! The front drop is what Im most concerned with when I look at aftermarket springs 'cause the rear has already assumed a lower stance than when new. Even when new, I could feel that there was performance left on the table with this set up, but I thought that other spring/damper combos would ride too stiff for street use. The BMR Strano Koni KYB stuff looks like maybe the best of both worlds! My car is for pleasure use only, but going too hard core by having my car scraping and having little compliance would be a mistake. As for the rear, Ground Control makes rear end weight jacks(ers?) but they're big $.
Old 09-24-2009, 08:17 PM
bongva's Avatar
wow I have BMR springs as well, but your drop is a lot lower than mine.... is there a mod that you did to have it that low? i would like mine at that drop as well
Old 09-24-2009, 10:31 PM
Nope, just everything i have listed in the first post and a local performance shop to do all the work.
Old 09-24-2009, 10:33 PM
bongva's Avatar
looks great man! think u can get some measurements?
Old 09-24-2009, 11:52 PM
I can, but it'll be a couple months. Im back over in Iraq until December 7th.
