Recommend me a cam
Old 09-24-2009, 11:51 AM
sw07gt's Avatar
Default Recommend me a cam
So I've got a a 2002 Z28 M6 with K&N FPIK, full exhaust, ported throttle body, and full exhaust. I plan on also getting new heads and intake but I have no idea which ones or when that will happen. I've been considering the MS3, Torquer V2, and the Texas Speed 233/239 cam. I want something thats going to make good power but not be too extreme.
Old 09-24-2009, 12:15 PM
teke184's Avatar
i would remove the MS3 from that list.
the Tv2 is a good cam, my Tv1 is very easy to drive on the street, other than the clutch being touchy (stg 4 w/ alum flywheel). i can cruise around town at 1200-1500rpm no problem.
and having <.600" lift will increase your options for heads that won't require flycutting.
that cam, with something like some stg2.5 5.3L heads and a ported FAST would yield 450rwhp.
my Tv1 made whats in the sig on stock heads and a stingy dyno.
Old 09-24-2009, 12:19 PM
brians91formula's Avatar
Get a custom grind cam for your set-up. I dont think you will like the MS3.
Old 09-24-2009, 02:12 PM
1Loudz28's Avatar
my vote goes to the v2. i have the f13 which is almost identical, and it drives great and makes good power up top.
Old 09-24-2009, 03:45 PM
MUSTANGBRKR02's Avatar
I have two cars with the V2 both drive great. M6 puts down 413/396 to the wheel but is a dog till 34XX.
Old 09-24-2009, 05:11 PM
LargeOrangeFont's Avatar
good info!
Old 09-24-2009, 06:19 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Checkout the V3 if you have the spring for the extra lift. It's without a doubt better across the entire useable rpm! We also have a new 229/234 camshaft that's working very well for us! I'd personally go Torquer 3 without a doubt!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-24-2009, 11:24 PM
transamfreak01's Avatar
would you have to flycut with the tv3?
Old 09-25-2009, 07:15 AM
teke184's Avatar
Tv3 fits under stock heads.
but it will limit your head options down the road a bit.
Old 09-25-2009, 09:19 AM
Like the guy above stated, you will NOT need to flycut with a stock long-block.
__________________
