Need New Trans Mount
Ok guys, I've got a 2000 WS6 LS1 T56 with a broken trans mount. Not only has the drivetrain shifted (gotta force it in reverse), but it rattles at idle and in reverse.
I've heard that a poly trans mount and stock rubber engine mounts can add extra stress to the trans housing during hard acceleration (365hp). Also, I've got a McLeod master cylinder with a Centerforce clutch, so I don't want to shock the 10 bolt too much, even though I've got a girdle on it.
I read an old thread that talked about using an auto mount because the stock manual mounts are oil filled or something. Suggestions?
I can't find a stock rubber mount outside of GM. However, I'm open to suggestions.
Don't know about the 3.8L tranny mount being the same or not, but where in the world did you hear that the manual mounts are oil filled? I'd just get yourself a stock mount because a poly mount will transmit more NVH to the cabin of the vehicle.
This thread is being made because I can't get a stock mount outside of GM for the manual as far as I can find. (not looking for poly)
I've read that lots of people with rubber engine mounts and a poly trans mount break their transmission housing. This is because they have a stiffer trans mount than engine mounts.
