c5 with spray? gurus needed
Old 09-30-2009, 05:47 PM
SPRAYED Z's Avatar
Default c5 with spray? gurus needed
I have a 02 c5 that is fully suspended with a drag radial. I want to install a kit and hit it with atleast a 150 and up to a 200. Can these cars handle that big of a shot with out a problem. Engine is completely stock with stock exhaust still lol. Only mod is a cold air intake and a muffler. Can I hit it with that amount and be safe and if so can anyone give me a idea of what it will run with a 150 shot or even a 200 shot.
thanks, Tom
Old 09-30-2009, 05:56 PM
Ruckus46Gt's Avatar
racetronix fuel system and you should be good to go with a tune
Old 09-30-2009, 05:59 PM
01ws666's Avatar
https://ls1tech.com/forums/nitrous-o...explained.html
Old 09-30-2009, 06:07 PM
robsquikz28's Avatar
I would say a 150 shot with ease and make sure you have a lean shutdown and get a good tune IMO. If you really want, wak it with a 200 shot, but thats me lol
Old 09-30-2009, 06:59 PM
Cape T/A's Avatar
i did this with a 125 shot on mine! good luck!
Old 10-01-2009, 05:39 PM
sprydncamd ta's Avatar
need a good tune and a quality product like harris speed works microedge +
Old 10-01-2009, 07:13 PM
therealcreeper's Avatar
is your car auto or 6 speed? keep in mind that stock 4l60e's are only rated at like 360 rwtq
300ish stock + gobs added by nitrous = not good for stock converter and stall for long
Old 10-01-2009, 07:26 PM
TransAm2002's Avatar
When my motor was bolt ons, I ran a 150 shot all the time. Run colder plugs and 100 octane and you will be fine. Now I run a 125 with the heads/cam set up. Would run a bigger shot, but so far that beats most everything out here in Vegas. lol
Old 10-02-2009, 01:02 PM
Well let me tell you their is a car down here that is a 01 c5 and its bone stock with stall even full stock exhuast manis, with cat and stock exhaust to the bumper. No ls6 parts or a cam, stock engine with a 150 wet kit that runs 10.8s all fukn day..
Old 10-02-2009, 03:29 PM
Nitro Dave's Nitrous Outlet's Avatar
The stock bottom end will safely handle a 150 shot. I would suggest upgrading the fuel pump for anything over a 100. There are people spraying 200 on the stock bottom end but they are understanding they are pushing the limits.
Keep in mind the key to safey doing nitrous is in the quality of the products and doing it correctly. Take time to seek the right people for technical knowledge and make sure the car is tuned correctly.
If we can answer any questions at all let me know. I will be happy to guide you down the correct path. Feel free to shoot me a pm or call me for a one on one. I will answer any question you have.
Dave
