Some quick tech advise.. driving broken car..
Old 10-05-2009, 03:45 PM
coxta's Avatar
Exclamation Some quick tech advise.. driving broken car..
Ok so earlier this summer I bent pushrods and valves in my car. I replaced the pushrods to find out I had bent valves. It does still run and drive just not very healthy as you might imagine.
I HAVE to move my car from where its at now to my home 20 miles away. Nobody around has a car trailer that I can load it on to haul it.
My question is will it hurt to baby the hell out of it and drive it the 20 miles slowly? Its out in western Kansas so its all open highway, no stop-and-go traffic.
Some advice needed quick as my car has to be out by this weekend. Thanks in advance!
Old 10-05-2009, 03:58 PM
ss_slowmaro's Avatar
Hire a tow truck, think about the cost of a truck compared to the cost of possible repairs
Old 10-05-2009, 05:04 PM
PREDATOR-Z's Avatar
Bent valves will wear out guides, so instead of just replacing valves you'll have to get new guides as well. (assuming your guides are still good)
Worst case a valve stem could break off and sayonara engine.
Old 10-05-2009, 08:36 PM
coxta's Avatar
im putting on new heads all together. I already have them: Stage 1 TSP CNC stage 1 LS6 heads with trick flow dual gold valve springs
The 1 tow truck we have in town said $200
Old 10-05-2009, 09:26 PM
eallanboggs's Avatar
Rent a towbar.
Old 10-05-2009, 09:57 PM
dwfronk's Avatar
Go to U-Haul and get a wheel dolly. I know there are some U-haul places around there i used to live in Garden City.
Old 10-05-2009, 10:01 PM
MurderedOut's Avatar
ditto.
Old 10-05-2009, 10:37 PM
coxta's Avatar
there might be one in Sharon Springs. Yeah Garden City is 2hrs away
Old 10-06-2009, 05:22 AM
coxta's Avatar
another concern is the 2 1/2 miles of gravel road. but i guess as long as they drive extremely slow it should be fine if they used a dolly
Old 10-06-2009, 06:52 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Get a Flat bed and be done with it.
Old 10-06-2009, 07:20 AM
niceguyyy01's Avatar
x2 get the rollback and be done. Very bad idea to drive it.
Old 10-06-2009, 08:10 AM
99RTA's Avatar
If it starts and runs they can't be bent too badly....drive it. Nothing is going to magicly happen because you run it with bent valves. becha they are only bent a few thous or it wouldn't runat all.
Old 10-06-2009, 08:15 AM
IWGF's Avatar
Figure something out cuz if it drops a valve while you baby it home, you're out a motor. Tow that bitch.
Old 10-06-2009, 08:16 AM
IWGF's Avatar
This is one of the dumbest posts I've seen in a while.
Old 10-06-2009, 08:32 AM
99RTA's Avatar
Bull ****! that car can be driven..i seen lots of engines with bent valves driven HARD afterwards. Like i said if it starts and runs theu anit bent that bad. Bectcha the guys posting up don't drive NEVER seen a bent valve!
Old 10-06-2009, 08:53 AM
eseibel67's Avatar
You are on perfectly straight, level ground?
I would tow that sucker home with a rope because I'm as cheap as you are.
Old 10-06-2009, 09:21 AM
IWGF's Avatar
I've seen bent valves break and ******* destroy a motor. It's a bad deal. Rather be safe than sorry and spend a few bucks to tow it home rather than drive it, blow the bitch up, and be building a new motor.
Old 10-06-2009, 09:38 AM
99RTA's Avatar
If those valves were gonna break they would have already. Maybe running the **** out of it with bent valves could cause a stem to break but he is just going to drive it easy. Drive it already damit! These guys are like chicken little.....
Old 10-06-2009, 09:43 AM
99RTA's Avatar
So you were driving with bent valves huh? BULL ****!
Old 10-06-2009, 09:51 AM
Jassick's Avatar
actually I'd probably do this. If it's all flat, find some real heavy duty rope, and tie it up good. have somebody ride in the drivers seat in case the rope breaks so you can brake and pull over. Not sure of the legality of that set up though.
