Turn signal socket & Window motor
I've tried a search but came up with nothing. I'm looking for instructions on how to change out a turn signal socket cause mine burnt out and the window motor for obvious reasons. Mods I was not sure where to post this so feel free to redirect it. Thanks guys.
The window motor I haven't done before.
The turn signal socket, you can go to an autoparts store and buy the socket. What I did was just cut off the socket. There's three colored wires. Just spliced the matching wires. That was it
The socket I would think is just a cut/splice...
The window motor on the other hand...
Here is a writeup I used when doing mine...
http://shbox.com/page/windowmotor.html
I'd imagine it'd be similar to this:
http://www.fbodyonline.com/rear-side...nector-how-to/
As far as the window motor, just follow the how-to posted earlier.
http://www.ls2.com/forums/showthread...ghlight=signal
no reason to cut and splice,
This walkthrough is easy to follow. It worked great for me for 5 years before I sold the car.
Ryan
Ryan
http://www.ls2.com/forums/showthread...threadid=15143
ps- when changing your sockets, dont do it from underneath from the access doors. pop the headlights and remove the bezel; youll have a lot more room to work with and you wont be on your back. before you take everything apart, make a diagram and write down where each color wire goes and how the new socket go backs together. i usually make dash marks and i line them up when i put it back together.
pss- when changing window motor, use a 6"-8" length of 2x4 to hold your window up. just stick it between the window glass and the bottom portion of the door.
Ryan
Ryan
Ryan
Ryan
