clutch pedal depressed but car wont let me engage gear
Old 10-06-2009, 04:51 PM
daves94formula's Avatar
Default clutch pedal depressed but car wont let me engage gear
just got done putting the motor back in the 95Z and hooked everything back up tranny wise. fired the car up and let it run then i decided to make sure the clutch was working so i tried putting it into gear while on jacks and with the pedal depressed i cant engage the shifter. even with the pedal all the way to the floor as soon as i move up to any gear you feel it hit a "wall" and the tires would start to spin. with the car off i can move into every gear with the pedal depressed. im at a loss of what it could be. any help would be app. car has a mcleod ST with the steel flywheel and a mcleod adjustable master.
Old 10-06-2009, 07:16 PM
iansane's Avatar
Clutch fork bolt backed out/not tightened? System not completely bled? Fork not sitting correctly on TOB? What HAVE you tried?
Old 10-06-2009, 09:55 PM
going to try rebleeding the system again. going to get my dad under the car and have him look and see whats going on while its depressed.
Old 10-07-2009, 10:50 AM
Gen414's Avatar
More than likely improper bleeding is cuplrit
Old 10-07-2009, 08:34 PM
OZ38's Avatar
Does it have one of those self adjusting pressure plates fitted as stock ?
Cheers
Old 10-12-2009, 10:31 PM
Stang-Slayer's Avatar
Im kind of having hte same problem......Hate to sound like a n00b but what u mean baout hte fork and the TOB?
Old 10-12-2009, 10:38 PM
98TADRIVER's Avatar
lol dont worry about it. LS1's dont have the fork, but they do have a throwout bearing.
to the OP, id say try bleeding it again, maybe adjusting the master cylinder after that if need be
Old 10-13-2009, 02:36 AM
think i might have found the problem. since its a street twin it has the floater in between the disks. dont think the shimming was right. its back within mcleod specs right now. all thats left is to bolt the tranny and the rest of the drivetrain back up and give it a shot.
Old 10-13-2009, 06:54 AM
if you could keep us updated man
Quick Reply: clutch pedal depressed but car wont let me engage gear
