clutch pedal depressed but car wont let me engage gear
just got done putting the motor back in the 95Z and hooked everything back up tranny wise. fired the car up and let it run then i decided to make sure the clutch was working so i tried putting it into gear while on jacks and with the pedal depressed i cant engage the shifter. even with the pedal all the way to the floor as soon as i move up to any gear you feel it hit a "wall" and the tires would start to spin. with the car off i can move into every gear with the pedal depressed. im at a loss of what it could be. any help would be app. car has a mcleod ST with the steel flywheel and a mcleod adjustable master.
to the OP, id say try bleeding it again, maybe adjusting the master cylinder after that if need be
think i might have found the problem. since its a street twin it has the floater in between the disks. dont think the shimming was right. its back within mcleod specs right now. all thats left is to bolt the tranny and the rest of the drivetrain back up and give it a shot.
if you could keep us updated man
