Car sits crooked
Old 10-06-2009, 11:21 PM
kcsov6's Avatar
Default Car sits crooked
I have always noticed my car sits sort of crooked but never really bothered me until as of late. The passenger side literally sets about 2.25 inches higher than the driver side. My driver side quarter panel is only about an inch or so above the tire (looks lowered), the passenger side looks higher than stock should. What could be causing this and how could it be fixed?
Old 10-06-2009, 11:28 PM
gun4hire's Avatar
Lots of info on this via search...
Old 10-06-2009, 11:32 PM
kcsov6's Avatar
yeah most of it comes up as aftermarket suspension problems, stock suspension here n a lot of the people even with aftermarket are only claiming small differences, I measured my difference at a lil over 2"
Old 10-06-2009, 11:39 PM
gun4hire's Avatar
From what I've read, a lot of people with stock springs have had this problem. However, a 2" difference is a LOT. I'd get the car on a lift and check to make sure none of your suspension components are damaged. Was the car ever wrecked by you or a prior owner?
Old 10-06-2009, 11:40 PM
therealcreeper's Avatar
it is very common for the passenger side to sit LOWER than driver side. check your springs. otherwise maybe the previous owner removed 1 isolator and not the other. 2 inches is a big difference. start taking it apart.
Old 10-06-2009, 11:47 PM
kcsov6's Avatar
previous owner had wrecked it, not sure what to check tho, I have some ramps or do I need it on racks?
Old 10-07-2009, 12:06 AM
gun4hire's Avatar
You could put it on ramps and have a look...wont hurt anything and you may spot something obvious.
However, 2" is a LOT and may not allow the car to track straight or become unpredictable in a panic situation. I would take it to a reputable suspension/alignment shop if you dont find anything obvious with a casual inspection.
Old 10-07-2009, 12:24 AM
kcsov6's Avatar
this may be a dumb suggestion as I am new to suspension, but could bump stops (I think is what they are called) effect it?
Old 10-07-2009, 02:51 AM
gun4hire's Avatar
No. Bump stops are there to protect your frame/suspension components at full compression (bottoming out). When the car is sitting still, the bump stops are just hanging out doing nothing.
Old 04-01-2010, 02:38 PM
hoffmanzach's Avatar
did you ever figure this out? mine was wrecked also and sits about a inch higher on the drivers side. Its driving me nuts but not much i can do for it.
Old 04-01-2010, 08:13 PM
trnsfmr99's Avatar
I agree with Gun4hire. Also, is your car a t-top or a hard top? If its a t-top, your frame may be twisted. Do you have subframe connectors? If not, along with checking with the frame alignment shop and your parts under the car, they will tell you if your frame's twisted or not. I have the same problem with my car, but on the passenger side and its fortunately not a 2" difference. Good luck with your car.
Old 04-01-2010, 09:57 PM
sschoeffler's Avatar
Same problem happened to me. Pulled the front wheels off the ground about 8 inches with a 6 speed, come down when I shifted and it come down hard, scraped the front crossmember to hell. I'm pretty sure its my shocks though, nothing looks bent.
Old 04-02-2010, 02:28 AM
mannyman84's Avatar
your just fat man! jk jk man.......check your spring compression. make sure they are all evend out as close as possible.. springs wear out after so many years, if u can take all of them out and put fronts together and rears together left and right separate on their side. and see if they all stand the same height......if not then u need new springs..thats if u can take them off
Old 04-02-2010, 02:48 AM
jc98ss's Avatar
just buy new springs so that the whole thing sits low!!...bmr's or strano..... my eibach's will be replaced soon
Quick Reply: Car sits crooked
